Acrylic enclosure for PINE A64
#41
(04-14-2016, 05:16 AM)killor Wrote:
(04-13-2016, 12:23 PM)rahlquist Wrote:
(04-13-2016, 11:51 AM)pine.tree Wrote: Hey, a free smart watch isn't that bad of a deal Tongue
Really considering this a good smart watch would be like considering Mr Ed (reference for those unfamiliar https://www.youtube.com/watch?v=czsNX9agMxc )  a good secretary....
Ahhh !! Now I understand...
I'm sorry for what just happened..
For AMAZON error cost me a couple of dollars (Refund Fee) !  Angry
but if you've been happy now , I am also happy. Smile
The video  Acrylic enclosure can help to make assembly.
If you have questions, contact us for help ..
Thank you
G. Perez
Whoa! Wait a minute! They are charging you for part of the refund??
I placed an order for your case.
The put the wrong item in a box and shipped it to me, probably sent my order to a wrong person too.
Now they want to penalize you?!?!? WTH
Thank you
G. Perez
Exactly how it works AMAZON, they always win ..
Fortunately, these cases are not common and there are the many successful transactions..
Thank you
G. Perez
Wow you are a lot more calm about that than I would be. that it totally wrong from any point of view. Jeff Bezos should be ashamed.  I could understand if the return was because the product didn't meat your claims, but this ways 100% Amazons fault. I wonder how many millions they make ripping off their sellers like this.
(04-13-2016, 12:23 PM)rahlquist Wrote: Really considering this a good smart watch would be like considering Mr Ed (reference for those unfamiliar https://www.youtube.com/watch?v=czsNX9agMxc )  a good secretary....
Thank you
G. Perez
These are the "rules of the game AMAZON" and if you do not like, do not play ..
The important thing is that you like the enclosure and the to recommend to your friends !! Big Grin
By the way if any part is broken or lost, send me a message to send you a free replacement ..
I encourage you to post your comments on the announcement of AMAZON, so that other clients learn from their shopping experience.
Thank's
PD: They are on their way to AMAZON, 23 units more ...
(04-14-2016, 07:12 AM)killor Wrote: These are the "rules of the game AMAZON" and if you do not like, do not play ..
Thank's
Oh I plan on taking lots of pics etc. Wink
Acabo de comprar la mía en Amazon US. Espero que llegue todo bien
Sent from my iPhone using Tapatalk
It's here. Assembly will have to wait till after I get off of work. For now though;
http://imgur.com/a/SuPQe
Looks good Smile
Ok, it is fully assembled and I like it. I give the case a 9 out of 10 and the packaging for shipment a 8 out of 10 (when I opened the paper packet in the second photo and upended it, screws went everywhere). The only thing I would change about the case itself if the way the battery is held in is by a screw, could be easy to over tighten.
Other than that there is adequate space around the holes for connectors and everything is where it should be. I appreciate that when it ships the larger holes are 99% cut but the large pieces are left in for you to decide if you want to push them out or not.
Great case and definitely worth the price! If anyone has any questions, needs measurements to see if <XXXX> will fit, let me know.
(04-14-2016, 12:04 PM)rahlquist Wrote: It's here. Assembly will have to wait till after I get off of work. For now though;
Looks good Smile
Thanks for your comments..
These were the first LOT units,  and we have already made some improvements.
Now, we have the screws into a separate bag.
we have changed the screws on the battery connector, (they are now 6mm longer)
Yes, the openings are for everyone it opens when you think that is necessary ..
The remaining holes in the lid are screwing other boards  like POT Board sensors, Raspberry PI HAT board, etc.
Thank you for your help.
G. Perez
(04-14-2016, 11:52 AM)RicardoM68 Wrote: Acabo de comprar la mía en Amazon US. Espero que llegue todo bien
Estimado Ricardo,
Gracias por su compra !!.
En youtube tengo un video de como ensamblar la caja,(esta puesto al principio de este hilo) aunque es un video de la primera versión y no esta el proceso del porta baterias para el reloj.
Por cierto la bateria CR2032 de boton no esta incluida, pues los envios de pilas desde el extrajero son dificiles de enviar.
Pero en Amazon los puede comprar tambien, Pila boton CR2032
Si tiene algún problema,le ruego nos envie un mensaje para ayudarle..
Un saludo,
G. Perez
There's no assembly instructions!
Sent from my iPad using Tapatalk
No trae instituciones de ensamblaje [emoji2]
(04-16-2016, 02:19 PM)RicardoM68 Wrote: There's no assembly instructions!
See the video on youtube thanks!!
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 243,328 11-02-2020, 08:43 PM
Last Post: Little_Johnny
  Are the Pine64 Acrylic Open Enclosures Stackable? abhinava 5 16,176 09-17-2020, 06:41 AM
Last Post: dabou
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 33,204 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 52,268 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 19,004 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 30,748 07-18-2017, 10:39 AM
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 17,378 07-16-2017, 01:51 AM
Last Post: selina3
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,734 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 13,158 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 10,113 02-12-2017, 10:17 PM
