As promised to @Jeremiah Cornelius in the Initial Impressions thread, I am posting some of my initial findings with Reaper on the PBP. My setup is as follows:
OS: Debian/MATE default image (Kernel 4.4.207 - Latest MrFixit updates)
Reaper: v6.02 (armv71)
Audio Interface: Behringer U-Phoria UMC202HD
Microphone: RØDE NT1-A
Installing and running Reaper was fairly straightforward. Just follow the instructions on the Reaper website.
After starting up Reaper I was only getting input from the built in Microphone. I had to switch PulseAudio to use the Behringer interface.
Once that was resolved. Everything recorded correctly.
I did notice that on the right side USB port everything worked fine. The left side USB port introduced lots of latency and was unusable. I have not tested my USB-C hub because I do not want to introduce more latency. Although this might be an interesting testing at a later stage.
I won't subject you to my test recording. It was done in my echo-y office and my voice is not exactly great.
But, I have included a screenshot of the setup.
I will also try to grab some CPU performance screenshots but I have not got around to doing that yet.
I should also mention that the use case I have (or rather my wife) is that of Audiobook narration. So it is a single mono track recording with very few filter and effects to reduce some room noise. It is not the most taxing workload but it is good to see that the PBP can cope quite nicely. Doing multiple tracks with lots of effects may not work quite so well.
