Installing Printer
Hi. Received my new Pine64 Pro a few days ago and very happy with it buuuuuuut!
I installed Brother 2130 Laser Printer drivers from the Brother website after installing CUPS.
Nothing prints to the printer and only rubbish via PDF, it all looks good except the results.
http://localhost:631/printers/HL2130  shows everything OK.
Any help please?
I'm a bit of a newbie so if via terminal I details please. Sad
TIA
I also tried to install my printer (Canon) but was unsuccessful because it requires drivers that are meant (compiled?) for arm architecture. The drivers on the Brother website are probably not meant for arm architecture. Did you download drivers specifically for arm architecture?
If you dig down to the bottom, after 3 layers of scripts, you will find i386-elf (filter driver)
This, of course, will never work on arm (and there are NO arm filter drivers, unless you compile)
Read my post,,, CUPS, 50%,, about 2 weeks ago
In short, using stretch, mtfixit, cups is too old for airprint, don't waste your time, you will not succeed
--edit--
Not strictly true, when airprint is successfully setup, there are scads of aarch64 binaries in /lib/cups/....
Ordinarily, from the brother website, it will be assumed x86, the deb or rpm will install to /opt/brother/....
There are NO aarch64 drivers on their website, all aarch64 come with a airprint-driverless install*
Even works (airprint) with a rk3328 TV box, prints OK, if 3 requirements are met
(printer not too old, cups 2.2.4 or newer, networked,, the last can be worked around)
*I am guessing, from what "file" tells me, that they are "sucked" off the printer by avahi
Search,,,,, debian airprint AND debian driverless
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,366 12-13-2023, 07:22 PM
Last Post: trillobite
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 4,031 11-28-2022, 05:03 PM
  Problems installing/ booting a different Linux on PinebookPro v-man 3 7,759 03-22-2022, 06:37 PM
Last Post: pentamassiv
  Installing debian on pinebook pro (deb installer/emmc) ljones 14 26,050 02-08-2022, 02:47 AM
Last Post: Humid Stylus
  Installing cinnamon on Manjaro PBP [SOLVED] quixote 1 5,815 05-09-2021, 01:39 PM
Last Post: quixote
  installing OS from SD to eMMC methods for flashing SD PineHead7 3 12,003 12-22-2020, 06:52 PM
Last Post: jiyong
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 17 33,493 11-19-2020, 03:16 AM
Last Post: FeMike
  Printer driver lib32-glibc dependency definitiv. 4 9,717 07-05-2020, 08:04 AM
  Upgrading eMMC and Installing Majaro XFCD 20.06 lyssa 0 3,239 07-01-2020, 05:27 PM
Last Post: lyssa
  boots not after try installing arch definitiv. 3 9,431 06-17-2020, 04:06 PM
Last Post: definitiv.
