Pinebook won't boot (from eMMC)
I tried to go back to the default install of Debian. However, after dd to the eMMC, the PBP doesn't want to boot. The active LED goes on and flickers for some time, the backlight goes on, then the power LED goes out and after some time the backlight goes out as well. Then everything starts again.
I'm coming from Manjaro if that matters. Any ideas on how to recover from this (SD boot works fine)
This is the thread the Pinebook Pro wiki recommends to perform a system restore. I have not performed the operation myself, I can only point the way:
https://forum.pine64.org/showthread.php?tid=8229
Moderator edit: Updated thread title to include "(from eMMC)" as it's different symtom than not booting at all. Let me know if that's in-correct.
Arwen Evenstar
Princess of Rivendale
(12-28-2019, 01:30 PM)brent.thierens Wrote: I tried to go back to the default install of Debian. However, after dd to the eMMC, the PBP doesn't want to boot. The active LED goes on and flickers for some time, the backlight goes on, then the power LED goes out and after some time the backlight goes out as well. Then everything starts again.
When you boot from the SD card now, is the EMMC mounted or available to mount?  If not,  you may need to hit the reset button (28 on the diagram,  and it says reset (in timy, tiny letters :-) )
I assume when you dd'ed it you had a copy of the default image on your ssd card which you used as input?
I have a MicroSD emmc Reader attachment--I believe  you can also get usb EMMC readers--which makes it easier to use something like etcher on your desktop to write the emmc. I believe that aside from the store having them,  you could get one from Amazon.  Also having a serial cable available makes debugging easier.
If you are worried that something has happened to the emmc , itself,  you can always reinstall the manjaro, using their emmc installation sd, to make sure the hardware is still working,  then boot from their SD card version, download the default image to the sd card and dd it over  to the emmc...
Thanks for your answers. I think the eMMC is just fine. When I boot from SD, the eMMC seems to be just fine: I can see the partitions, I can dd to it etc. I tried flashing Manjaro, works just fine. I booted Debian from an SD, also fine. When I flash that image (coming from a faster USB3 drive, my SD isn't that fast), it doesn't boot.
Seems like there was an error in the image. Thanks anyway for the help!
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 11,962 08-09-2025, 06:53 AM
Last Post: Sb2024
  Boot Order in Pinebook Pro food 11 10,341 03-28-2025, 10:08 AM
Last Post: DrYak
  Pinebook pro won't boot after bootloader installation jwensouls 4 5,530 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 3,015 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 8,594 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 11,351 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 7,161 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 8,251 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 134,526 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 2,440 12-07-2023, 03:11 PM
