Trackpad firmware update
#51
I applied this update and now all of my problems have gone away.
By the way, I really enjoy typing on this machine. The keyboard feels great for such an inexpensive laptop.
#52
So, I've noticed something over the last several days of use with the new firmware... While the keyboard fix has remained in place, I've noticed that the trackpad enhancements have reverted somewhat. To expand on this, the old pointer overshoot issue is still gone however a sort of dead zone has appeared which makes pointer precision similar to the pre-update behavior. This is mostly just feedback for the devs, the behavior overall is still improved and I'm happy that the update was made available to us. Hopefully the dead zone issue can be mitigated in the next update (should there be one).
#53
(11-22-2019, 09:42 AM)Luke Wrote: Credit goes to @tllim , @xalius , @ayufan and @anarsoul
N.B. This trackpad/ keyboard firmware update applies to all Pinebook Pros produced in 2019
Before you start:
Your Pinebook Pro should be either fully charged or, preferably, running of mains. This utility will be writing chips on the keyboard and trackpad, so a loss of power during any stage of the update can result in irrecoverable damage to your trackpad or keyboard.
The scripts ought to work on all OSs available for the Pinebook Pro. Some OSs may, however, require installation of relevant dependencies.
Please report any issues you encounter in this thread.
What you'll need:
  • Your Pinebook Pro fully charged / running of mains power
  • Connection to WiFi
  • An external USB keyboard/ access to the Pinebebook Pro via ssh
What you need to do:
Please follow @ayufan's instructions exactly
Instruction Brief (read original instructions for further details):
make
First Step:
sudo ./updater step-1
sudo reboot
Second Step:
sudo ./updater step-2
sudo reboot
LUKE :
  Should everyone do this update, (?)
     my track pad and keyboard seem to operate just fine.
  (Keyboard, track pad including edge scroll and all)
   After sitting for a few days my keyboard did not register every key press,
    but after using it for a few minutes all the keys seem to respond....  ?
   I am thinking I may do the firmware update when it or if it becomes a problem..?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
#54
Before you start:
What you'll need:
make
First Step:
sudo reboot
Second Step:
sudo reboot
LUKE :
In my opinion, everyone *should* do the update as it vastly improves the trackpad and keyboard performance. But it is obviously voluntary, and its your choice whether you wish to upgrade or not.
#55
(11-24-2019, 05:02 AM)Jeb5Blovrueb Wrote:
(11-24-2019, 03:22 AM)ayufan Wrote: In some cases you might have to retry `step-2` a few times. Detection of boot mode is sometimes flaky.
I've tried that many times, but it always fails.
Today, I've completed step-2 with success, my trackpad is working again Smile
What I've done:
    - boot my pinebook pro with the manjaro preview
    - installed make, gcc, ... and compiled the updater
    - ./updater step-2
#56
I value your opinion so I will do shortly,
BUT maybe wait a day or two to see if the simplified method becomes available
Thank You much for your assistance
RUN the Compiler 1st,
Then step 1
Then step 2
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
#57
(11-26-2019, 03:25 PM)bcnaz Wrote: **
Then step 1
Then step 2
Yes, its pretty straight forward Smile
ayufan has pretty detailed instructions too, so you can take a look at that.
#58
AND it requires a usb keyboard ?
I do not have one of those but I can purchase one...
Ordered a brand new usb full keyboard, under $10 USD, and it will be here Monday.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
#59
(11-26-2019, 05:20 PM)bcnaz Wrote: AND it requires a usb keyboard  ?
I am pretty sure that you can get away with not using one, if you can manipulate the PBP using the keyboard alone + via ssh.
An external mouse/keyboard just make the process easier - but its not necessary
#60
With the updater on Manjaro, I had issues with step-2. In the KDE session it failed even after 5-10 attempts (also a few restarts).
Switching to tty2 completed step-2 from the first try.
If someone else has issues with completing the update, is worth a shot.
  Locked out after update Shylocked 5 4,063 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 9,696 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 3,390 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 3,248 02-22-2023, 03:23 PM
Last Post: robocone
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 5,761 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 8,303 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 4,500 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 4,711 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 12,086 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 2,991 11-18-2021, 06:37 PM
Last Post: reundo
Users browsing this thread: 12 Guest(s)
