for what purpose Pine64 added PCIEx4 card on this sbc ?
What is the purpose of adding PCIE-x4 slot on rockpro64 ? and what is the speed limit ?
For example to add NVMe or SATA disks.
Speed limit x4, AFAIK most disks are the limit rather than the bus.
(11-23-2019, 05:24 PM)dukla2000 Wrote: For example to add NVMe or SATA disks.
Have you tried PCIE card made by other make than Pine64 ?
When you use random PCIe cards it depends on a couple of things, a lot of the more complex cards have an option ROM or general ROM that contains some firmware that is run on the main CPU, but it's firmware for x86 ... so the card will not initialise. There are some projects out there that try to run the option firmware during boot with emulation, but that's very experimental. For some cards, there is actually ARM firmware you can update from the vendor, but I have only seen that for expensive 10 and 40Gbit NICs.
edit: https://www.suse.com/c/revolutionizing-a...m-aarch64/
(11-25-2019, 06:06 AM)seaurchin Wrote: Have you tried PCIE card made by other make than Pine64 ?
I've used 2 different NVMe adapters, neither of which was made by Pine64, and I haven't had problems with either of them.
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 3,374 11-26-2024, 11:08 AM
  Rockpro64 with PCI FC Card - Not booting (Sometimes) MSteam 1 4,114 10-25-2020, 07:42 PM
Last Post: MSteam
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 8,395 10-20-2020, 10:52 AM
Last Post: GreyLinux
  micro SD Card Slot Spring not working, Cant boot mjembd 1 4,401 04-16-2020, 12:30 AM
Last Post: mjembd
  Defective? PCI-E -> SATA card no work good unregisteredidiot 11 19,187 02-19-2020, 09:08 AM
Last Post: fysa
Sad RockPro64 with OpenMediaVault - Ethernet card is not recognized eduapof 8 17,024 04-18-2019, 08:28 AM
Last Post: g_t_j
  Request for comments -- Pine64(TM) PineBookPro(TM) Wishlist Faradn 0 1,962 04-04-2019, 04:21 PM
Last Post: Faradn
  7″ LCD Pine64 touch screen + RockPro64 + Linux Impact 0 3,868 02-07-2019, 04:03 AM
Last Post: Impact
  SD Card UHS speed hopkinskong 5 9,409 12-06-2018, 05:52 PM
Last Post: z4v4l
  Rock64Pro PCI-E card issues celer 0 2,772 10-14-2018, 07:32 PM
Last Post: celer
