Trackpad firmware update
#21
Success! Thank you all for your hard work. No more broken text input. ^_^
#22
Just updated here, it worked flawlessly. Thanks!
#23
(11-22-2019, 03:20 PM)tophneal Wrote: @ayufan should this update be possible from a shell in your Chromium build, or should I boot up a Linux drive?
No, just Linux.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
#24
No, just Linux.
Thanks. Luckily seconds after asking the Manjaro team made their version available and I'm updated now.
Open question: does anyone know if the necesity to type slowly is a hardware or firmware isue? As you can se here, every word using repeating leters is a problem, even when I intentionally slow my typing. (Unless I go hunt-and-peck sped. It's a bit beter then, but stil not great.)
#25
A bit delayed trying this fix out today, didn't get to give it a go over lunch as expected. Now that I am home though, I just finished up the process as described above and man oh man is it a night and day difference. I had zero issues performing the flash via SSH. I am going to put the track-pad through its paces tonight and try to do the rest of my work for the evening on the PBP! Thanks again @Luke, @ayufan , and the rest of the team for facilitating this fix and getting word out to the rest of us who needed saved from our impatient selves. Cheers!
#26
Worked like a charm for me. Big thank you to everyone involved! It types proper now. Fairly certain I could wage a decent flame war with it now. I'm off to find out.
#27
(11-22-2019, 04:45 PM)tophneal Wrote: Open question: does anyone know if the necesity to type slowly is a hardware or firmware isue? As you can se here, every word using repeating leters is a problem, even when I intentionally slow my typing. (Unless I go hunt-and-peck sped. It's a bit beter then, but stil not great.)
  I am not having that issue on the default Debian in Leafpad or LibreOffice Writer....maybe Manjaro preview issue?
#28
Manjaro and Chromium. Had the problem while posting to the manjaro forum booted from it, and again booted from chromium, posting here.
#29
How can I check the firmware version? What's the current version and what was the previous one?
#30
(11-22-2019, 08:49 PM)Der Geist der Maschine Wrote: How can I check the firmware version? What's the current version and what was the previous one?
You can't.
Releases:
Buy me a Beer
  Locked out after update Shylocked 5 4,063 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 9,696 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 3,390 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 3,248 02-22-2023, 03:23 PM
Last Post: robocone
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 5,761 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 8,303 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 4,500 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 4,711 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 12,086 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 2,991 11-18-2021, 06:37 PM
Last Post: reundo
Users browsing this thread: 11 Guest(s)
