Pinebook Pro spares kit
Anyone else want a Pinebook Pro spare parts kit?
Here is my current list, in priority order;
- Bottom case screws, at least 1 each of short & long
- Rear hinge spacers, 2
- CPU thermal pad
- Laptop disassembly kit, plastic pry tool(s)
And potentially a miniature precision screw driver
I already have the last 2, laptop tools and various screw drivers. But, I can see where someone else would want / need them. Plus, it makes a dedicated kit for the Pinebook Pro. (I once had a laptop SSD failure while traveling. Could not repair because I did not have the parts and tools with me.)
Arwen Evenstar
Princess of Rivendale
I see there are some Pine stores in other countries.
Such as one in California for the USA as an example.
Perhaps those could sell such 'kits' ?
That would reduce shipping cost and time by a lot.
It would cost perhaps $,50 cents US compared to $8.99
Sent by my New PBP
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
100% in support of this! Spares kit is a great idea and very much needed particularly over the long run. The spacers break relatively easy and the tiny screws are easily lost so probably should have several in a kit. Replacement thermal pads when needed are CPU life saver. Might offer kits with and without tools unless too many SKU's is a problem.
(11-17-2019, 12:35 PM)Arwen Wrote: Anyone else want a Pinebook Pro spare parts kit?
- CPU thermal pad
As I mentioned in other threads, I would like to get the generic specifications for these parts.
Although I have no objections to Pine64 offering parts kits.  Shipping may be slow and expensive, compared to other sources.
(11-17-2019, 12:35 PM)Arwen Wrote: - Laptop disassembly kit, plastic pry tool(s)
As far as know, Pine64 does not use any uncommon screw heads.
Unlike Apple, which uses tri-point, pentalobe, etc., just to be difficult  Angry
Supporter of spare part kits.
Also eager interested in parts specifications.
Would like to add a usb-c power supply for the PBP.
All spares, except for the battery (due to shipping issues), will be available in the store eventually
(11-18-2019, 04:07 AM)Luke Wrote: All spares, except for the battery (due to shipping issues), will be available in the store eventually.
Excellent, I opened mine yesterday to change emmc and found one of the spacers in pieces.  Must have been misaligned when I put it back together last time.
Perfect.
I've not opened my PBP yet, and don't have a need for spare parts. (My eMMC seems seated well, and I don't have WiFi issues that would suggest a loose antenna.)
Arwen Evenstar
- A Pine sticker for the case.
- More than two spare spacers.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 7,058 01-02-2026, 04:26 AM
Last Post: stu73
  pinebook pro dixplays vertical stripes WEF 2 3,127 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 3,668 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 3,313 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 3,260 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 2,842 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 5,227 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 199,683 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 12,667 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 11,085 12-27-2022, 03:31 PM
Last Post: samtux
