Archlinux (mainline) for Pinebook
#51
(08-27-2019, 04:27 PM)conlaoch Wrote: Anyone else have trouble updating their Arch distro?  Twice now after an update its done something to the resolve.conf and then paceman can no longer resolve hostnames.  This makes Pacman die most spectacularly.  The last time I reverted to an unchanged resolve.conf and that worked.  But this time I have been unable to get it to work.  The annoying thing is drill seems to work just fine.  Drill <hostname> seems to find the info without any issues, but paceman and the web are broken.
Much as I love Arch, this kind of strange behavior is enough to make me go look for another distro that works as expected.
And yes, I understand that Arch is not a distro for newbies, but i've been running it off and on for the past 6=8 years and this is the first time i've had this trouble.
Although I am on a different machine I use ArchLinux ARM myself and experienced this problem sometime back.  After weeding through a ton of posts I found a reddit entry that worked for me.  Check your /etc/systemd/resolvd.conf, and set DNSSEC=no then restart systemd-resolvd.  YMMV but it worked for me, am attaching link to post below.
https://www.reddit.com/r/archlinux/comme...ame_issue/
#52
(08-28-2019, 07:40 AM)wolfen1125 Wrote: Although I am on a different machine I use ArchLinux ARM myself and experienced this problem sometime back.  After weeding through a ton of posts I found a reddit entry that worked for me.  Check your /etc/systemd/resolvd.conf, and set DNSSEC=no then restart systemd-resolvd.  YMMV but it worked for me, am attaching link to post below.
The did indeed fix the issue.  Thanks a lot!!!
  DietPi OS for Pinebook MichaIng 5 15,975 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,099 05-18-2026, 02:11 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 100,808 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,498 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,177 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 15,666 04-13-2023, 01:09 PM
Rainbow Customised (encrypted) eMMC installation using Anarsoul's ArchLinux Blutkoete 24 54,713 05-02-2022, 12:59 PM
Last Post: thunderweasel
  Stock Debian on original Pinebook moonwalkers 1 8,060 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,246 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 10,937 05-07-2021, 10:20 AM
