PCIe ath10k on RockPro64
I am trying to get a QCA988X wifi miniPCIe module to work.
I am using adapter from miniPCIe to to the PCIe x4 slot. All in chain should support PCIe 2.1 spec.
As far as I get is to get the module recognized in lspci.
Kernel module ath and  ath10k_core are loaded. But I think ath10k_pci is missing. When I compile a custom kernel with this module, or compile a module to the existing kernel, I always get kernel panic on loading the module. (modprobe -v ath10k_pci).
Some ideas on how to get the card to work?
Yes I need exactly that card.
(08-07-2019, 07:26 AM)dasfranky Wrote: Hi,
This is just a shot in the dark, as I don't own this hardware. But when you look in /lib/firmware, is there an ath10k directory? If not you probably need the firmware-atheros package.
The firmware can also be found here:
  https://git.kernel.org/pub/scm/linux/ker....git/tree/
Already did install the firmware. still not working. I asume ath10k_pci is missing. But i. An not compile a working one.
what does the following say?:
  $ sudo modinfo ath10k_pci
(08-07-2019, 01:36 PM)Ehmuller Wrote: what does the following say?:
This module does not exist, or not found in /lib/modules/...
I also don't have that hardware..
See if this helps you  Shy
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,859 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 182,666 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,374 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  RK3399 PCIe enumeration jhadd 0 3,470 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 5,213 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,314 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,714 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 131,506 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,852 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,313 03-12-2023, 06:55 PM
Last Post: quixoticgeek
