Notebook-workstation for power users?
I am a bit too much of a pragmatist. I will order a Pinebook Pro in the future -- my current laptops have worse specs, being about a decade old. The issues I have are with software -- photo processing and statistical analysis -- and at present I'm haning off for a couple of months waiting for the first issues to be sorted and at that time I'll probably have a dead laptop that I need to replace.
Rant on: most CPUs we have can do almost anything you want to do at a reasonable speed. Bar gaming, and perhaps video processing. The issue is having a kernel that plays nicely with the software. If you think of it, a Chromebook assumes that the cheap processors we have can run anything via a web browser. Power users now are either running massively parallel systems, or gamers. Rant off.
(07-30-2019, 11:01 PM)weka Wrote: I am a bit too much of a pragmatist. I will order a Pinebook Pro in the future -- my current laptops have worse specs, being about a decade old. The issues I have are with software -- photo processing and statistical analysis -- and at present I'm haning off for a couple of months waiting for the first issues to be sorted and at that time I'll probably have a dead laptop that I need to replace.
"The issues I have are with software -- photo processing and statistical analysis"
If you have used Linux before and open source software, you won't even realise that you are not any longer on a X86 machine because they are identical on ARM and run natively. GIMP for photo processing and R Studio for statistical analysis are great open source applications you can run on Pinebook.
The problems start when you are trying to run proprietary software and drivers. If you stay away from them you are okay.
I haven't used windows or Apple OS for years now and I can do all my scientific work on Linux perfectly fine.
  Looking for PineTime users to test an Android app with BLE heart rate support Mitrax 2 2,974 03-11-2026, 02:50 PM
Last Post: Mitrax
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 2,115 10-03-2025, 11:35 AM
Last Post: cowsay
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 4,105 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 4,454 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 4,962 04-08-2025, 08:31 PM
Last Post: colajuices
  Pine Desktop PowerSupply wont power on BSharp 6 8,770 01-07-2025, 08:04 AM
Last Post: skare
  Help with high voltage power supply setup for electrospinning? namarang 2 5,546 10-13-2024, 09:38 AM
Last Post: zetabeta
  Firmware Update for PinePower Desktop Power Cycling Issue TimothyRodriguez 1 3,289 05-03-2024, 12:53 AM
Last Post: Pavlos1
  Link USB power strips for a cluster? shanefe 1 3,273 04-02-2024, 11:11 PM
Last Post: evilbunny
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 2,912 09-02-2023, 10:13 AM
Last Post: lupyuen
