Android and Ethernet
I successfully installed Android on my Pine64 (2gb) with a 32gb Sd card. My usb wifi module doesn't seem to be recognized, so i tried using the ethernet port with no luck Sad i know my Computer is setup properly to share internet (Raspi) i just can't seem to get it going, any suggestions?
a lot of Android apps dont recognize Ethernet - what are you using? I was able to access Playstore, Chrome, etc via Ethernet.
(03-30-2016, 09:46 PM)arpanj2 Wrote: a  lot of Android apps dont recognize Ethernet - what are you using? I was able to access Playstore, Chrome, etc via Ethernet.
The first thing I had tried was the Play Store, no luck, tried Chrome, looked into my settings no LAN being seen(ethernet is plugged in and lights are flashing)
Android 5.1.1
2gb pine64+ here... ethernet flashes and shows activity, but android doesn't seem to recognize it. Guess I should've bought the wifi dongle.
(04-01-2016, 10:14 AM)jchawk2003 Wrote: 2gb pine64+ here... ethernet flashes and shows activity, but android doesn't seem to recognize it. Guess I should've bought the wifi dongle.
Please advise on the network configuration, I like to know why your board Ethernet doesn't been recognize. Try unplug and plug in Ethernet cable again and check whether this help the connection.
I share my internet, works with everything else, except for the Pine, both lights show up...orange and blinking green, but no internet is recognized.
Sent from my SM-N900P using Tapatalk
(04-01-2016, 10:07 PM)W1SPY Wrote: I share my internet, works with everything else, except for the Pine, both lights show up...orange and blinking green, but no internet is recognized.
If no Internet connection, this implies that Pine A64 board doesn't get IP address assignment. Try to unplug and plug in teh Ethernet cable and check whether able to get IP address assigned.
I do have the same experience. The first boot with the network cable connected didn’t work, after the PINE 64A logo I had a white screen for more then 15 min. Without the network cable the first boot did work (After the PINE 64A logo, the desktop of android came), and all reboots after the first boot it starts correctly with the cable attached.
The big issue now: Android doesn't work correctly with the Ethernet connection. The IP assignment is done (see screenshot). A soon I will open the browser I can see the webpage logo or header filled with the webpage name, but no way the page will load completely. The Google Play store, which tries to connect with the Internet will report a timeout message.
Can someone point us in the right direction? Where to search to get more logging?
Device: PINE 64A 2GB version
Image: sun50iw1p1_android_db1000_uart0_0216.img
Network connection: 1000 MB
I installed OS Monitor to check the log of Android (via USB stick with a apk file), I filtered the log messages (see log file).
2016-04-02 11:20:54,DEBUG,OpenGLRenderer,OS Monitor,Use EGL_SWAP_BEHAVIOR_PRESERVED: false 2016-04-02 11:20:54,DEBUG,Atlas,OS Monitor,Validating map... 2016-04-02 11:20:54,WARNING,Atlas,OS Monitor,Pointer 0x0, not in getPreloadedDrawables? 2016-04-02 11:20:54,WARNING,Atlas,OS Monitor,Pointer 0x0, not in getPreloadedDrawables? 2016-04-02 11:20:55,INFORMATION,OpenGLRenderer,OS Monitor,Initialized EGL, version 1.4 2016-04-02 11:20:55,DEBUG,OpenGLRenderer,OS Monitor,Enabling debug mode 0 2016-04-02 11:20:55,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 11:20:55,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.android.externalstorage: Resource ID #0x0 2016-04-02 11:20:58,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 11:20:58,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.android.shell: Resource ID #0x0 2016-04-02 11:20:58,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.google.android.configupdater: Resource ID #0x0 2016-04-02 11:21:03,DEBUG,OpenGLRenderer,OS Monitor,endAllStagingAnimators on 0x7f89f1f400 (RippleDrawable) with handle 0x7f8d240d40 2016-04-02 11:21:06,DEBUG,OpenGLRenderer,OS Monitor,endAllStagingAnimators on 0x7f807b3000 (RippleDrawable) with handle 0x7f8d2701a0 2016-04-02 11:21:50,INFORMATION,Choreographer,OS Monitor,Skipped 35 frames!  The application may be doing too much work on its main thread. 2016-04-02 12:54:22,INFORMATION,art,Unknown,Background partial concurrent mark sweep GC freed 62315(4MB) AllocSpace objects, 257(4MB) LOS objects, 40% free, 12MB/20MB, paused 3.692ms total 177.105ms 2016-04-02 12:54:59,WARNING,art,Unknown,Before Android 4.1, method int android.support.v7.internal.widget.ListViewCompat.lookForSelectablePosition(int, boolean) would have incorrectly overridden the package-private method in android.widget.ListView 2016-04-02 12:55:02,WARNING,InputEventReceiver,Unknown,Attempted to finish an input event but the input event receiver has already been disposed. 2016-04-02 12:55:34,WARNING,osmcore,Unknown,type=1400 audit(0.0:3): avc: denied { syslog_read } for scontext=u:r:untrusted_app:s0 tcontext=u:r:kernel:s0 tclass=system permissive=0 2016-04-02 12:55:37,WARNING,InputEventReceiver,Unknown,Attempted to finish an input event but the input event receiver has already been disposed. 2016-04-02 12:55:48,DEBUG,OpenGLRenderer,Unknown,endAllStagingAnimators on 0x7f83389c00 (RippleDrawable) with handle 0x7f922619c0 2016-04-02 12:55:51,WARNING,Resources,Unknown,Converting to string: TypedValue{t=0x10/d=0x2 a=-1} 2016-04-02 12:56:10,DEBUG,OpenGLRenderer,Unknown,endAllStagingAnimators on 0x7f833d3000 (RippleDrawable) with handle 0x7f92343500 2016-04-02 12:56:19,INFORMATION,art,Unknown,Background partial concurrent mark sweep GC freed 54156(3MB) AllocSpace objects, 214(4MB) LOS objects, 39% free, 13MB/21MB, paused 2.153ms total 121.109ms 2016-04-02 12:56:36,VERBOSE,OSMCore,Unknown,force Exit 2016-04-02 12:56:37,INFORMATION,Process,Unknown,Sending signal. PID: 26487 SIG: 9 2016-04-02 12:56:43,DEBUG,OpenGLRenderer,OS Monitor,Use EGL_SWAP_BEHAVIOR_PRESERVED: false 2016-04-02 12:56:43,DEBUG,Atlas,OS Monitor,Validating map... 2016-04-02 12:56:43,VERBOSE,OSMCore,OS Monitor,use file system Unix domain socket 2016-04-02 12:56:43,INFORMATION,OpenGLRenderer,OS Monitor,Initialized EGL, version 1.4 2016-04-02 12:56:43,DEBUG,OpenGLRenderer,OS Monitor,Enabling debug mode 0 2016-04-02 12:56:44,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:56:44,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.android.providers.userdictionary: Resource ID #0x0 2016-04-02 12:56:44,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:56:44,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.google.android.gsf: Resource ID #0x0 2016-04-02 12:56:46,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:56:46,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.android.externalstorage: Resource ID #0x0 2016-04-02 12:56:46,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:56:46,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.android.packageinstaller: Resource ID #0x0 2016-04-02 12:56:46,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:56:46,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.android.defcontainer: Resource ID #0x0 2016-04-02 12:56:46,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:56:46,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.google.android.partnersetup: Resource ID #0x0 2016-04-02 12:56:46,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:56:46,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.google.android.gsf: Resource ID #0x0 2016-04-02 12:56:59,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:56:59,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.android.shell: Resource ID #0x0 2016-04-02 12:58:44,WARNING,ResourceType,OS Monitor,No package identifier when getting value for resource number 0x00000000 2016-04-02 12:58:44,WARNING,PackageManager,OS Monitor,Failure retrieving resources for com.google.android.gsf: Resource ID #0x0 2016-04-02 01:00:01,INFORMATION,art,OS Monitor,Background sticky concurrent mark sweep GC freed 36814(2MB) AllocSpace objects, 241(4MB) LOS objects, 37% free, 12MB/19MB, paused 5.553ms total 85.808ms 2016-04-02 01:00:17,INFORMATION,art,OS Monitor,Background sticky concurrent mark sweep GC freed 45174(1545KB) AllocSpace objects, 78(1248KB) LOS objects, 24% free, 8MB/11MB, paused 9.155ms total 33.023ms
I also included screenshots: http://imgur.com/a/QYVST
[Image: TAKqkii.png]
[Image: e6V2qa6.png]
[Image: YkWscyX.png]
[Image: 6czh0b1.png]
[Image: QfHP8YX.png]
[Image: XysrUXD.png]
[Image: 1iOvBOo.png]
I am having the same issue. I have an ip address and Google Chrome will even goto an address but 90% of the content won't load. Its like being dial up. But not upset and can't wait for the fix.
I see a similar complains in the various threats. They say there is an issue with the 2 GB board, which is not recognized correctly...
Is there a way to update drivers in Android and do some re-testing? Can we ask user:longsleep to have a look? He did a fixed on the Arch Linux image.
http://forum.pine64.org/showthread.php?t...19#pid4719
Can the Pine team help?
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,568 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 606,914 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,162 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,001 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,672 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,234 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,551 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,734 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 409,138 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,493 02-26-2019, 11:58 AM
Last Post: Twistedx
