RockPro64 boot problem
I'm using a Rockpro64 board with ArmBian distribution.
The board is connected via HDMI to a display and via USB to the touch screen controller.
When the USB of the touch screen controller is connected the RockPro64 does not boot: it stuck in the boot room, on the console the only message I get is:
DDR Version 1.22 20190506
In
then it stuck waiting for something.
If instead I remove the usb connection vs the touch controller, the RockPro64 boot normally.
Any ideas about the root cause of this problem? ANy solution?
Thanks in advance
BS
Max
I own two "rockpro64" boards.
And, I confirmed that one of them shows similar symptoms.
The problem occurs on a board with 4GB of RAM, no problem with 2GB of RAM.
Is this problem simply due to individual differences ?
Or is it due to differences in board RAM options ?
It can not be judged because the number of samples is small.
Is your "rockpro64" board 2GB? Is it 4GB ?
And what string is printed on the silk mark on the board ?
(06-20-2019, 04:33 PM)t4_4t Wrote: I own two "rockpro64" boards.
I'm using 2GB board. I'm not inthe office right now, so I can't telle you the string on the silk mark...
Max
  RockPro64 automatically run after power recovery - my solution g2t 1 569 05-28-2026, 05:29 PM
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,143 06-21-2025, 06:21 AM
Last Post: aleksei
  where to get debian 12 image for rockpro64? heocb 1 3,679 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,156 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 4,674 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,072 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 26,309 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 207,691 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 5,349 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 3,811 09-08-2023, 08:14 AM
