RockPro64 UPS for in car use
Hi, so I am looking for a UPS in car use. So I could shut down vehicle power and my RockPro64 would turn off itself without any corruption. Anyone has any suggestions which would work with rockpro? I have found so many, but not sure which one would be compatable.
Hey bro. I wrote about power management in the other thread you posted.
You need to find out if RockPro64 has some kind of pwr_off pin which can be shorted with another pin to imitate power button. My Odroid XU4 has a dedicated PWR_OFF pin which can be shorted with any of 1.8-5v pins to initiate shutdown process. So I simply connected my Mini-Box DC-DC 200 board to these pins. What the Mini-Box board does is it detects ignition switching and shortens the pins on my Odroid XU4 and waits around 40 secs to make sure the board shuts down. After 40 seconds it completely cuts the power from car battery.
When you turn the ignition on the Odroid XU4 gets power automatically and starts. The board from Mini-Box also has protection so you don't fry your single board computer.
If RockPro64 has similar pins you can use it will be pretty easy (still not very cheap) to do that.
(03-18-2019, 10:09 AM)fender90 Wrote: Hey bro. I wrote about power management in the other thread you posted.
[Image: G4sfZ6f.png]
I added header pins to the locations circled and use a standard momentary switch.  The OS you use can decide what the response is.  Hope this helps
I am also trying to do some sort of power backup just for few mins so that i can gracefully shutdown the rockpro64.
It will be great if i can get few comments on my querries.
1) In above highlighted circle, What should be the connection to replicate the power button function? should i short REC pin to PWR pin? or REC pin to GND. I am not able to find the document regarding these 4 exposed pins.
2) Which type OS shutdown is good shutdown? from command line or direct Pin shorting.
I think for propper shutdown i should use propper command line shutdown.
To achieve above condition, is there any dedicated module from pine or anywhere? Basically i want if power goes then there is some module which gracefully shut it down and when power comes back, my rockpro64 get power on.
Thanks.
  Powering two disks from RockPro64 some_pinephone_user 3 863 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 2,886 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 10,481 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 3,325 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 41,552 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 3,195 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 5,205 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 14,115 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 3,772 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 12,493 07-18-2022, 10:05 PM
Last Post: zer0sig
