Cases and Enclosure Question
#61
Im searching for the specific measures of the pine 64 , every port location ( HDMI , Ethernet , ... ) , the actual shematics aren't that specific only the
measure of the hole pine 64 architecture and i need them actually to make my Case and it will be with plex so i don't wan't to make
any error . Thanks you .
I have measured my newly arrived board and created my own drawings and 3d models.
These are all based on measuring my single board so may not be correct for other peoples boards and I obviously have no tolerance information but perhaps they will be useful to someone until the real drawings are released.
And before anyone says anything my board was 127 x 79.5mm as measured with my calipers and not the 127 x 79mm that has previously been mentioned
files can be found https://github.com/kyllikki/designs/tree...ne64_Board
(04-02-2016, 05:56 PM)kyllikki Wrote: I have measured my newly arrived board and created my own drawings and 3d models.
Thank you!!! Finally a complete drawing... perfect for finishing my casing.
Thanks very much it's make a while im searching for those measure im think im not the only one ~
Can I share your information on Pine64 wiki page?
... TL Lim
... TL Lim
sure, its licenced as creative commons by attribution, so as long as you credit me its fine
... TL Lim
thanks and will do the proper credit :-)
This is great, but can your software export or save as a real solid file, such as STEP? Using Solidworks and Fusion 360 that STL is somewhat buggy and difficult to translate to a solid model.
Glad someone took the time, though, and looking forward to designing a solid aluminum or copper case for the board sitting in front of me.
Edit: I took a different route and imported the DXF into Fusion 360 and created a solid model from the DXF sketch. I used the board sitting in front of me. I'd be happy to share if anyone wants a non-STL version, and can export as STEP, IGES, SAT or SMT, or as a .F3D file if someone wants to directly edit my extrusion parameters and edit the solid from the original.
Edit 2: I added important chip locations (for heat sinks), will probably add pinouts later. For now this works.
[Image: Tr5IsWh.jpg]
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 239,922 11-02-2020, 08:43 PM
Last Post: Little_Johnny
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,629 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,422 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,491 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,870 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,892 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,141 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,025 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 31,469 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 28,576 11-01-2016, 06:23 PM
