EasyOS 1.0.4 running on Rock64
For anyone who is interested:
http://bkhome.org/news/201902/easyos-ver...ock64.html
To get a quick overview of what EasyOS is all about, see here:
https://easyos.org/about/how-and-why-eas...erent.html
I have been running Easy on the Rock64 for several days, it is completely stable, have been compiling huge packages, such as LibreOffice and the kernel.
Regarding the kernel, thanks to ayufan, I just downloaded from his repo, patched aufs and simplified the .config (mostly took out debugging stuff).
Booted from SD card, I have not yet tried putting it onto the eMMC.
Regards,
BarryK
ok, i'll probably give it a try once i unpack the rock64 [i moved recently]. otherwise, i think "matter" exists in the physical world and comes in various forms. the conscious formulates an internal representation of the matter, this is perception. take for example, your room at night, if you turn on the lights you perceive all types of matter around you, if you turn off the lights and the room is completely dark you perceive nothing since you can not see the matter, however the matter still exists, you just have no internal representation. off topic i know but i just had to throw it out. if you want to continue a discussion on your theory start a thread in general. otherwise, i will let you know what i think about easyos later. thanks.
(02-02-2019, 04:45 AM)BarryK Wrote: For anyone who is interested:
Regards,
BarryK
Hello Barry,
Please advice where should download the EasyOS image file.
I tested easy-1.0.4-aarch64.img.gz (http://distro.ibiblio.org/easyos/aarch64...yro/1.0.4/) where it will stuck after running awhile.
Note Booted from Micro SD Card
Please advice.
Thank you
Pineadmin
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,226 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,809 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 96,388 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,032 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,435 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,444 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,932 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,105 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,999 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 117,684 09-01-2024, 06:05 AM
Last Post: RaymondDay
