Disable HDMI Pine64
Hello everyone!
How can i completely disable (periodically, by cron) HDMI port on Pine A64?
Whats command?
It's needed for completely disabled monitor (picture and backlight).
kernel - 3.10.105-bsp-1.2-ayufan-77
- "DISPLAY=:0 xset dpms force off" blanking picture only, but not turning off backlight
- sunxi tools changes screen resolution only, but not power manage.
- "echo 0 > /sys/class/backlight/lcd0/bl_power" doesn't work
Pls help, Thnx)
(01-28-2019, 04:29 AM)Andruxa89 Wrote: but not turning off backlight
According to Pinebook schematic, the LCD power is controlled by GPIO PH6, so you can turn it off using :
echo 230 > /sys/class/gpio/export echo out > /sys/class/gpio/gpio230/direction echo 0 > /sys/class/gpio/gpio230/value
and you can turn it on again with :
echo 1 > /sys/class/gpio/gpio230/value
EDIT : Ouupps !!! I didn't read the title properly, you were talking about HDMI on Pine64, while my reply is about Pinebook LCD ... Sorry !
  Unable to run hello-world docker container on Pine64 kamtschatka 2 9,634 01-24-2019, 04:29 AM
Last Post: arboehm
  KDE on pine64? jamiechang917 6 16,699 01-14-2019, 01:47 PM
Last Post: brigmohan
  External DAC - Pine64 mjgoode 2 8,180 09-05-2018, 12:12 AM
Last Post: mjgoode
  Summer Undergraduate Research using Pine64's pkivolowitz 3 8,833 05-15-2018, 08:17 AM
Last Post: pkivolowitz
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 4,713 07-08-2017, 09:34 AM
Last Post: petec
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 6,192 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  Node.js is not installed properly on Pine64 nsisodiya 1 5,781 12-29-2016, 12:48 AM
Last Post: longsleep
  Finally got Emby server running on Pine64 clarkss12 3 10,110 11-08-2016, 06:04 PM
Last Post: clarkss12
  Firefox on Pine64 S265 2 8,180 09-04-2016, 09:25 PM
Last Post: S265
  HDMI Overscan problem luke2389 8 18,135 09-02-2016, 10:22 PM
Last Post: Terra854
