Which OS is better to run on ROCK64?
#21
(12-11-2018, 05:11 PM)pantera Wrote: You've missed my entire point. I meant polling in GPIO terms and inexcusable to Pine.  As a software engineer, I should be able to set callbacks and not constantly interrogate the pins for voltage.
And you missed mine. It works for me. Simple as that.
As I said the GPIO pins situation is easily sorted with a Raspberry Pi, tried and tested for the job.
As a software engineer you above anyone should know when you embrace new untried and untested hardware with limited reference resources you are working at the bleeding edge and either come up with a solution of your own or move on to something that you can work with.
What I will say its a powerful piece of kit for the price and specifically for what I bought it for. I'm surprised a person with your level of expertise bought into something that clearly was not suitable for your purposes.
In this case my glass was half full and yours half empty. As far as I'm aware the supplier will refund your purchase price or there is a healthy used market demand for them out there. Clearly it is of no value to you at this stage.
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 3,918 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 93,038 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 20,406 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,795 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,037 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,049 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,752 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,941 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,813 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 115,485 09-01-2024, 06:05 AM
Last Post: RaymondDay
