Video Tutorial To Create Bootable SD-Card
Check out this video tutorial on how to create bootable SD-Card courtesy of Michael Larson.
http://wiki.pine64.org/index.php/Pine_A6...ther_Tools
Link doesn't go to video just the Wiki page. Am I missing something?.... or the coffee hasn't kicked in yet Smile
(03-26-2016, 10:31 AM)carb1a4h Wrote: Link doesn't go to video just the Wiki page.  Am I missing something?....  or the coffee hasn't kicked in yet :)
It was at the bottom of the Wiki Page, kinda hidden :P
https://www.youtube.com/watch?app=deskto...jJ62s5DxPc
If I've helped you with something, please leave a rating for my responses.
(03-26-2016, 03:27 PM)pine.tree Wrote:
(03-26-2016, 10:31 AM)carb1a4h Wrote: Link doesn't go to video just the Wiki page.  Am I missing something?....  or the coffee hasn't kicked in yet Smile
It was at the bottom of the Wiki Page, kinda hidden Tongue
DOH!   Yup, I'll blame the lack of coffee  Wink
Thanks for the reply p.t.
(03-24-2016, 09:52 PM)pineadmin Wrote: Check out this video tutorial on how to create bootable SD-Card courtesy of Michael Larson.
I cant seem to burn the image to my SD card I do not know what I am doing wrong. I have set up numerous raspberry Pi's just can not figure this out. Is it my computer that is limiting me? Please help?
What is the operating system of the computer you are using to burn the image? Which image are you trying to burn? Are you using an USB SD card reader adapter or the in-built SD card reader?
I am on windows 10. I tried both the android and Remix Os.I am using the built in SD reader. Thank you for helping.
I couldn't get any of my SD cards to be burned successfully on Windows 10. I used an old laptop with Windows 8, it worked the first time.
Your best bet is to find something without Windows 10 if it isn't too difficult- until there is a surefire method to making it work, i would stick with Windows 8/7 for burning.
Also, some people reported having troubles using the built-in SD card reader, whereas an external USB-based SD card reader worked.
That PhoenixCard software seems overly finicky and appears to run on voodoo.
There are links user posted images floating around here on the forum, so that you can use 'dd' via Linux-based command line, or Win32DiskImager on Windows instead. I'll see if I can find some of them...
Edit: yep, here is ML Anderal's RemixOS image.
And janjwerner's RemixOS image.
Hmm, can't currently find a straight Android dd image, though I thought there was one....
win32diskimager worked great with my samsung evo+ 64 gig card but with my Sandisk ultra 32 I had to use the phoenixcard burner ( format with the phoenixcard burner). win32diskimager said I didn't have enough sectors. I was installing android.
  How to create a valid firmware packet to update MiguelIrusta 1 3,165 10-28-2025, 10:02 PM
Last Post: henryclayton
  How to boot from SD card on pinebook pro linux123 3 10,457 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,196 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,262 06-19-2020, 06:58 AM
  Video conferencing aproject oxoocoffee 1 5,149 03-31-2020, 09:24 PM
Last Post: Dendrocalamus64
  How to boot from the SD card and install to eMMC? ravanh 2 10,409 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 303,997 03-03-2020, 11:34 PM
Last Post: siyatalerja
  Creating bootable Debian backup image Drago 3 10,003 12-11-2018, 03:42 PM
Last Post: evilbunny
  eMMC card on adapter Malmgren 8 19,069 03-20-2018, 11:14 AM
Last Post: Malmgren
  Mini-Tutorial to get a linux Desktop GUI working on Pine64+ speedro86 15 39,466 04-05-2017, 01:45 PM
Last Post: speedro86
