0.7.8 Linux release from ayufan for Rock64
Star
Hello everyone,
ayufan marked 0.7.8 as the new Linux release for Rock64.
As always you can upgrade to newest release:
sudo apt update -y sudo apt-get install linux-rock64 -y
If you encounter issues with this (or future 0.7.X builds) then report them in this thread or directly on github.
Enjoy!
How do I upgrade from previous stable?
> apt-get update -y [...] E: Repository 'http://deb.ayufan.eu/orgs/ayufan-rock64/releases  InRelease' changed its 'Origin' value from '' to 'GITHUB-AYUFAN-DEB-ayufan-rock64' N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details. > apt-get install linux-rock64 -y [...] linux-rock64 is already the newest version (0.6.44).
"man apt-secure" doesn't help me understanding what to do. Huh
I'm suddenly getting the following messages when I try sudo apt-get update and sudo apt-get upgrade. Any ideas? I have a 4GB RAM Rock64 with eMMC module installed (but no SD card installed). Everything was working fine until today and I tried the update.
I'm currently on "Linux rock64 4.4.126-rockchip-ayufan-239 #1 SMP Sun May 27 18:38:24 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux"
ERROR MESSAGES:-
The following packages have unmet dependencies:
linux-rock64 : Depends: u-boot-rockchip-rock64 (= 2017.09-rockchip-ayufan-1017-g7bd50d7e0f)
E: Unmet dependencies. Try using -f.
dpkg: error processing archive /var/cache/apt/archives/u-boot-rockchip-rock64_2017.09-rockchip-ayufan-1017-g7bd50d7e0f_all.deb (--unpack):
trying to overwrite '/usr/local/sbin/rock64_upgrade_bootloader.sh', which is also in package u-boot-rock64 0.6.59
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
(07-24-2018, 11:20 PM)LeoD Wrote: How do I upgrade from previous stable?
i have exactly the same messages...
ayufan is aware of the problem and will address the issue.
(07-25-2018, 12:38 AM)Pagliacci Wrote: I'm currently on "Linux rock64 4.4.126-rockchip-ayufan-239 #1 SMP Sun May 27 18:38:24 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux"
ERROR MESSAGES:-
the new kernel depend on the highlighted package which is not found by apt in any of your configured sources.
The best is to look for this package in ayufan's repository with the exact same version number as given (but it has most probably been forgotten along the way), and report an issue to ayufan's github page directly if not found anywhere.
Also, take a look at any special setup which may help.
Use "apt update" (not apt-get).
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
Will update my initial post, thanks !
Can you explain and resolve dual "extlinux/extlinux.conf" ?
  • first on vfat (efi) partition /dev/mmcblk1p6 and seems to be ignored (finally mounted to /boot/efi/...)
  • second on ext4 partition /dev/mmcblk1p7 and used with kernel images (finally mounted on /)
The problem is in "recovery" states. You cannot simply modify "extlinux/extlinux.conf" bootparemeters from windows hosts (on locally attached sdcard) (for example "single" parameter for recovery, "drm.debug=0x3f" to debug hdmi/drm settings/problems ...).
Can you explain and resolve many DTS and other booting errors in booting process ?
Kernel does not seems to be reliable with so many errors.
And yes, ayufan rk3328-rock64.dts is more better then original from rochchip-linux-4.4 that always crashes booting process.
... [    0.000000] rockchip_mmc_get_phase: invalid clk rate ... [    0.140599] Invalid sched_group_energy for CPU0 [    0.140640] Invalid sched_group_energy for Cluster0 ... [    0.542636] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]' [    0.542674] vcc_phy: no parameters [    0.542967] reg-fixed-voltage vcc-phy-regulator: vcc_phy supplying 0uV [    0.543062] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-sys[0]' ... [    0.544051] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    0.544076] vcc_sd: regulator get failed, ret=-517 [    0.544129] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    0.544148] vcc_sd: unable to resolve supply ... [    1.223069] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply from device tree [    1.223092] phy phy-ff450000.syscon:usb2-phy@100.0: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/host-port failed [    1.223598] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply from device tree [    1.223620] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up phy-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed [    1.224018] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up vbus-supply from device tree [    1.224039] phy phy-ff450000.syscon:usb2-phy@100.1: Looking up vbus-supply property in node /syscon@ff450000/usb2-phy@100/otg-port failed ... [    1.224061] phy phy-ff450000.syscon:usb2-phy@100.1: Failed to get VBUS supply regulator [    1.224959] rockchip-u3phy ff470000.usb3-phy: Looking up vbus-supply from device tree [    1.224981] rockchip-u3phy ff470000.usb3-phy: Looking up vbus-supply property in node /usb3-phy@ff470000 failed [    1.225004] rockchip-u3phy ff470000.usb3-phy: Failed to get VBUS supply regulator [    1.225511] phy phy-ff470000.usb3-phy.2: Looking up phy-supply from device tree [    1.225530] phy phy-ff470000.usb3-phy.2: Looking up phy-supply property in node /usb3-phy@ff470000/utmi@ff470000 failed [    1.225938] phy phy-ff470000.usb3-phy.3: Looking up phy-supply from device tree [    1.225957] phy phy-ff470000.usb3-phy.3: Looking up phy-supply property in node /usb3-phy@ff470000/pipe@ff478000 failed ... [    1.228711] phy phy-ff430000.hdmiphy.4: Looking up phy-supply property in node /hdmiphy@ff430000 failed [    1.231755] rk-vcodec vpu_combo: Looking up vcodec-supply from device tree [    1.231778] rk-vcodec vpu_combo: Looking up vcodec-supply property in node /vpu_combo failed [    1.231803] rk-vcodec vpu_combo: no regulator for vcodec [    1.232124] rk-vcodec vpu_combo: failed on clk_get clk_cabac [    1.232181] rk-vcodec vpu_combo: failed on clk_get clk_core ... [    1.236518] rk-vcodec vpu_combo: could not find power_model node ... [    1.375298] rockchip-drm display-subsystem: devfreq is not set [    1.376328] rockchip-vop ff370000.vop: invalid resource [    1.376858] rockchip-vop ff370000.vop: failed to get vop lut registers [    1.377490] rockchip-vop ff370000.vop: invalid resource [    1.377988] rockchip-vop ff370000.vop: failed to get vop cabc lut registers [    1.378925] rockchip-vop ff370000.vop: unable to request PWM ... [    1.386440] rockchip-drm display-subsystem: failed to parse display resources ... [    1.617194] Unable to detect cache hierarchy for CPU 0 ... [    1.742725] dwc2 ff580000.usb: Looking up vusb_d-supply from device tree [    1.742747] dwc2 ff580000.usb: Looking up vusb_d-supply property in node /usb@ff580000 failed [    1.742767] ff580000.usb supply vusb_d not found, using dummy regulator [    1.743726] dwc2 ff580000.usb: Looking up vusb_a-supply from device tree [    1.743745] dwc2 ff580000.usb: Looking up vusb_a-supply property in node /usb@ff580000 failed [    1.743760] ff580000.usb supply vusb_a not found, using dummy regulator ... [    2.549955] vcc_sys: could not add device link regulator.5 err -2 [    2.552281] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    2.552323] vcc_sd: unable to resolve supply [    2.563783] vcc_sys: could not add device link regulator.6 err -2 [    2.565637] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    2.565680] vcc_sd: unable to resolve supply [    2.588346] vcc_sys: could not add device link regulator.7 err -2 [    2.590027] reg-fixed-voltage sdmmc-regulator: Looking up vin-supply from device tree [    2.590071] vcc_sd: unable to resolve supply [    2.601410] vcc_sys: could not add device link regulator.8 err -2 [    2.625001] vcc_io: could not add device link regulator.9 err -2 [    2.639224] vcc_io: could not add device link regulator.10 err -2 [    2.653336] vcc_sys: could not add device link regulator.11 err -2 ... [    2.867433] cpu cpu0: Failed to get leakage [    2.867501] cpu cpu0: Looking up cpu-supply from device tree [    2.867602] cpu cpu0: Failed to get pvtm ... [    2.919022] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ff520000[0]' [    2.919032] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ff520000[0]' [    2.919039] dwmmc_rockchip ff520000.dwmmc: using lookup tables for GPIO lookup [    2.919049] dwmmc_rockchip ff520000.dwmmc: lookup for GPIO wp failed [    2.967348] dwmmc_rockchip ff500000.dwmmc: using device tree for GPIO lookup [    2.967356] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/dwmmc@ff500000[0]' [    2.967397] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/dwmmc@ff500000[0]' [    2.967408] dwmmc_rockchip ff500000.dwmmc: lookup for GPIO cd failed [    2.967425] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@ff500000[0]' [    2.967431] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@ff500000[0]' [    2.967441] dwmmc_rockchip ff500000.dwmmc: lookup for GPIO wp failed ... [    3.353038] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [    3.353051] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [    3.387771] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]' [    3.387784] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]' ... [    3.450384] of_dma_request_slave_channel: dma-names property of node '/serial@ff130000' missing or empty [    3.456564] ttyS2 - failed to request DMA, use interrupt mode ... [    3.830676] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]' [    3.830681] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]' ... [    3.923018] mali-utgard ff300000.gpu: Looking up mali-supply from device tree [    3.923150] mali-utgard ff300000.gpu: Failed to get leakage [    3.929522] mali-utgard ff300000.gpu: Looking up mali-supply from device tree [    3.929604] vdd_logic: could not add device link ff300000.gpu err -17 [    3.929623] vdd_logic: Failed to create debugfs directory [    3.929645] mali-utgard ff300000.gpu: Failed to get pvtm [    4.047500] devfreq ff300000.gpu: Couldn't update frequency transition information. ...
Away
mcerveny: /boot/efi/extlinux/extlinux.conf is legacy file, which is gonna be removed. If you want to modify boot params change `/etc/default/extlinux`, here is the docs: https://github.com/ayufan-rock64/linux-b...xtlinux.md.
Homepage: https://ayufan.eu
Releases:
Rock/Pro 64/Pinebook Pro: Linux; Chromium OS
So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1
Buy me a Beer
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 22,220 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,607 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 100,036 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,291 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,951 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,963 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,179 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,396 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,235 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 120,522 09-01-2024, 06:05 AM
Last Post: RaymondDay
