ROCK64 NAS problem
I am trying to move my NAS from a RPi2 to a ROCK64 (4GB).  Everything is working except I can't get the drives to mount at startup.  In the RPi version, it was done by adding the drive info to the fstab file.  When I do that on the ROCK64, it hangs during boot.  I can mount them manually on the command line via Putty on my Windows 10 Desktop.  After they are mounted, everything is working well, but if something causes the ROCK64 to reboot, I can't see the drives on the LAN until I mount them.  I wrote a script to mount the four drives with one command line, but I would like to have them mount automatically at startup.  I am running stretch-mate-rock64-0.5.15-136-20171222-arm64.
(06-24-2018, 04:09 PM)wjburl Wrote: I am trying to move my NAS from a RPi2 to a ROCK64 (4GB).  Everything is working except I can't get the drives to mount at startup.  In the RPi version, it was done by adding the drive info to the fstab file.  When I do that on the ROCK64, it hangs during boot.  I can mount them manually on the command line via Putty on my Windows 10 Desktop.  After they are mounted, everything is working well, but if something causes the ROCK64 to reboot, I can't see the drives on the LAN until I mount them.  I wrote a script to mount the four drives with one command line, but I would like to have them mount automatically at startup.  I am running stretch-mate-rock64-0.5.15-136-20171222-arm64.
That should not be a problem. Show us the content of your /etc/fstab and /boot/efi/extlinux/extlinux.conf
rontant, thanks for responding.
Since I made the original post, I gave up and installed Open Media Vault and that is working well. I don't think I'll revisit the original project. I guess I need to close this thread. This is my 2nd ROCK64 SBC and it is really outperforming my RPi2 by an order of magnitude.
Since I've overwritten the SD card, I can't I don't the data in /boot/efi/extlinux/extlinux.conf. The info I added to /etc/fstab was:
UUID=2291d8b3-ef45-469c-aa97-3c9fafa86f85 /media/OldIomegaDrive ext4 defaults,user,exec 0 0
UUID=0bc03e5c-4f6a-4b42-ab5b-ee62f191e328 /media/TCMMovies ext4 defaults,user,exec 0 0
UUID=05f8302e-3a6a-49db-99d1-00c4d6302425 /media/DriveDBackup ext4 defaults,user,exec 0 0
UUID=81e17742-2be9-42e1-888d-ad4cfea1c206 /media/Seagate5TBdrive ext4 defaults,user,exec 0 0
Sorry, did not see this before, but I believe in making life easy and I use Webmin to configure my Rock64 home server, it handles all mounting etc.. May be worth a look. I have never used Open Media Vault, so hope it is working well for you.
stealthbanana, Thanks. It took me a few attempts to get OMV setup the way I wanted, but it has been working well since. One issue I had was that my HDDs already had data and OMV wants to format the drives and start over. It doesn't let you share an entire drive, so I had to move the contents of a drive to a folder and share that folder. Now that it is working, I'm hesitant to try another option. My Rock64 is considerably faster than the RPi 2 I had been using.
It can produce a bit of messy output on the command line, but you can use CRON to do this pretty much bullet proof!
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,182 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 474 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 4,722 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 10,736 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,728 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,840 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 10,725 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 4,023 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 79,184 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 105,050 09-01-2024, 06:05 AM
Users browsing this thread:
