System boot from SSD with RockPro64.
The ROCKPro64 Wiki page specifically mentions 3 system boot options : SPI Flash, eMMC, and SD.
Does that rule out the possibility to boot from a SATA SSD, that’s connected to the RockPro64 SATA expansion card ?
(05-24-2018, 11:27 PM)Tigger Wrote: The ROCKPro64 Wiki page specifically mentions 3 system boot options : SPI Flash, eMMC, and SD.
Doesn't completely rule it out. The RK3328 that the rock64 is based on can also only 'only' boot from eMMC, SPI NOR, SPI NAND and SD/MMC... but the rock64 can also boot from USB and ethernet once you load uboot into the SPI NOR chip. So it is a matter of seeing if it is possible to get support for that in uboot for the RK3399, which incidentally has a SPI NOR -> SPI NAND -> eMMC -> SD/MMC boot order, so SPI is ahead of both eMMC and SD now in priority.
OK, so it's not in BIOS/UEFI. Uboot still needs to be installed on the board itself. I should have been more clear about that I meant the board booting Uboot directly from /boot on the SSD. I am interested in an autonomous installation. So that I can connect the SSD (with Arch Linux ARM or Android) to any RockPro64.
(05-25-2018, 05:32 AM)Tigger Wrote: OK, so it's not in BIOS/UEFI. Uboot still needs to be installed on the board itself. I should have been more clear about that I meant the board booting Uboot directly from /boot on the SSD. I am interested in an autonomous installation. So that I can connect the SSD (with Arch Linux ARM or Android) to any RockPro64.
Yeah, the onboard SPI NOR + uboot would be the nearest thing to a BIOS/UEFI equivalent on ARM. If the processor doens't support it directly for booting, it can't be booted directly. However, once you're in uboot... you're only limited to what it can do Wink
True. Uboot is pretty capable.
Thanks for explaining.
  RockPro64 automatically run after power recovery - my solution g2t 1 647 05-28-2026, 05:29 PM
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,178 06-21-2025, 06:21 AM
Last Post: aleksei
  where to get debian 12 image for rockpro64? heocb 1 3,718 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,183 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 4,705 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,095 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 26,585 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 208,548 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 5,380 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 3,842 09-08-2023, 08:14 AM
