sopine cluster board install
I picked up a sopine clusterboard with a bunch of computing modules. I am curious about how one loads os onto the compute modules. Do I need to get a usb finger drive for each compute module and plug it into the usb slot? Is the usb slot for the cluster usb 2.0 or 3.0?
Thanks,
(03-30-2018, 12:25 PM)Smurfbot Wrote: I picked up a sopine clusterboard with a bunch of computing modules. I am curious about how one loads os onto the compute modules. Do I need to get a usb finger drive for each compute module and plug it into the usb slot? Is the usb slot for the cluster usb 2.0 or 3.0?
Thanks,
USB sockets are USB2 - both the standard and microUSB one (although the current v2.2 cluster board has D+/D- reversed on the microUSB socket). To load your OS, 'simplest' way is to write an image to a microSD card for each. I'm sure someone will write a guide at some point outlining how to do fancier things like PXE booting the cluster so only either only the primary module needs to actually have storage (SD and/or eMMC) or from another source. You'll be wanting a Sopine image, and I'm running the current latest (0.7.19) ayufan xenial-minimal image with few issues.
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 5,142 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  PBP Debian 11 GRUB install error zlth 2 4,994 11-18-2022, 07:42 AM
Last Post: zlth
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,438 10-06-2022, 08:46 PM
Last Post: ihab
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,803 08-24-2021, 08:17 AM
Last Post: lamson
  1 of 7 SoPINE compute modules not receiving DHCP lease ClusterMaker 2 6,135 09-08-2020, 03:03 AM
Last Post: Dippywood
  wrong launguage install chadace 1 6,443 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 10,428 03-18-2020, 09:42 AM
  PSCI, u-boot and reboot on Sopine ClusterBoard hbaxmann 0 3,899 09-03-2019, 11:57 PM
Last Post: hbaxmann
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 26,700 05-15-2019, 02:55 PM
Last Post: Thatoo
  Rock64 suitable for headless TVHeadend install? elsmandino 3 10,247 06-26-2018, 11:37 AM
Last Post: Luke
