GPIO LED blinker using SYSFS on the Rock64
(07-12-2017, 06:25 PM)MarkHaysHarris777 Wrote:
(07-12-2017, 06:10 PM)tllim Wrote: Hi Marcus,
Lets create ROCK64 GPIO tutorial guide in PDF format and post at wiki site.
Yes;  I'm actually working on that !  ... I'll let you know when its ready.  It will also include the Python and C|C++ methods as well.
I updated my chart; while pin GPIO2_A3 does NOT work as output (it should) the pin DOES work as input !
... this was a surprise !
Hi
First of all thank you for your work. Very helpful!
I'd like to share a modified version of the function to calculate the pin number, with a bit of validation to be sure that the string is ok (I hope it is ok). The function returns -1 if there was any problem with the string
def GPIO_name2gpio(value): value = value.upper() if (value[0:4] != 'GPIO') or (value[5] != '_'): return -1 try: bank_num = int(value[4:5], 10) pad_nam = GPIO_pads[value[6:7]] pad_num = int(value[7:], 10) if (bank_num < 0) or (bank_num > 3) or (pad_num < 0) or (pad_num > 7): return -1; return (bank_num * 32) + (pad_nam * 8) + pad_num except (ValueError,KeyError): return -1
I noticed the pin numbers now have an additional offset of 1000 in the latest images (kernel 4.4.103).
Went ahead and wrote a Rock64 GPIO library for Bash: https://github.com/Leapo/Rock64-BashGPIO
Working on porting/re-implementing RPi.GPIO for Python now
(03-25-2018, 06:04 PM)Leapo Wrote: Went ahead and wrote a Rock64 GPIO library for Bash: https://github.com/Leapo/Rock64-Utilities
Nice work, can you maybe start a new thread for your RPi.GPIO effort, there are probably some people that would like to contribute...
(03-26-2018, 02:56 AM)xalius Wrote: Nice work, can you maybe start a new thread for your RPi.GPIO effort, there are probably some people that would like to contribute...
I'll fire up a separate thread as soon as I get the first version of the Python module uploaded to github. Shouldn't be too much longer.
I got basic functionality hammered-out and working last night. Check it out, R64.GPIO is already running RPi.GPIO compatible test code:
[Image: Xsa8Izu.png]
I have issue when trying the code MarkHaysHarris gave :
ulysse132@rock64:~$ sudo -i [sudo] password for ulysse132: root@rock64:~# echo 101 > /sys/class/gpio/export -bash: echo: write error: Invalid argument root@rock64:~#
Could you give me a hand to make this work ? I have the same result with echo 60. I didn't try other values because I don't want to make mistakes.
I use armbian 5.42 (stretch).
Thanks for your help !
#19
(07-03-2018, 11:30 AM)ulysse132 Wrote: Hello,
Export numbers have changed due to kernel updates and the like. I'll double check what the offset is now and let you know.
#20
I'd also like to know more about making this work on Armbian 5.42 stretch. My /sys/class/gpio only lists 5 items, gpiochip1000, 1032, 1064, 1096, 1510. Is this now accessing them as a group? I'm specifically wanting to use them as triggers so that a button press will trigger events in my python app.
  Rock64 v2.0 u-boot SPI issues ju0n 1 1,627 09-25-2026, 11:19 PM
Last Post: mysy
  Disable MicroSD reader for extra GPIO mxruben 0 12,737 07-27-2024, 10:08 PM
Last Post: mxruben
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,455 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 29,671 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 17,370 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 19,605 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 5,089 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 10,344 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 11,358 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,755 11-29-2022, 11:31 AM
Last Post: Macgyver
