Disable MicroSD reader for extra GPIO
Hello! I am working on a project that requires nearly all of the GPIO pins on the rock64. 7 of the GPIO pins are unusable while the microSD card reader is in use. To fix this, I installed armbian onto a usb drive and am booting from it now instead. However, I am still unable to set the GPIO pins that were in use by the microSD card reader. My guess is that it is still active, even though it is not reading anything. I think I need to do something to disable it. Has anyone found a way to access these GPIO pins?
  Python GPIO Library for the Rock64 (R64.GPIO) Leapo 37 117,786 07-02-2021, 03:20 PM
Last Post: klausfelix
  UARTs from GPIO headers maks.dav 1 4,499 10-27-2020, 12:06 PM
Last Post: martinayotte
  Disable Auto Power On Rock64 willowen100 4 8,702 03-11-2020, 08:24 AM
Last Post: Rocklobster
  MicroSD Speed? (UHS?) PoV 10 21,112 08-07-2019, 12:48 PM
Last Post: mcerveny
  Wich GPIO numbers use for ROC-RK3328-CC? robotgruntxd 1 6,128 04-27-2019, 02:13 PM
Last Post: robotgruntxd
  C++ GPIO seg fault on Rock64 using Pine64-CPP Jeff R 1 5,811 02-06-2019, 07:40 PM
Last Post: Jeff R
  GPIO LED blinker using SYSFS on the Rock64 MarkHaysHarris777 20 71,255 08-09-2018, 10:52 AM
Last Post: ulysse132
  Can't burn a microSD! Taht works catsinheat 6 11,697 03-28-2018, 07:53 AM
Last Post: catsinheat
  Dual boot microsd/eMMc? chitenavi 2 6,841 10-06-2017, 02:03 PM
Last Post: chitenavi
