Linux Images (ROCK64)
#81
(08-04-2017, 04:06 AM)pineadmin Wrote: ayufan just released the latest Linux Images (0.4.16-83) for ROCK64. Please visit his GitHub for released notes and visit the related links below on our Wiki:
Community Build Debian Stretch Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build Debian Jessie Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial Mate Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial Minimal Linux Kernel ver 4.4 [microSD Boot]
Community Build Xenial i3 Linux Kernel ver 4.4 [microSD Boot]
Community Build Jessie OpenMediaVault Linux Kernel ver 4.4 [microSD Boot]
I'm new to the ROCK64 and was wondering if a particular build stands out as  the 'most stable' on this board (I plan to use it as a NAS controller.)
Thanks!
You should always use the latest release (in this case 0.5.15) if you intend to use an image for other than testing. Some 0.6.X images may work better than others ... some not at all.
ayufan's git
(01-25-2018, 04:54 AM)matteobp Wrote:
(01-24-2018, 10:07 AM)ayufan Wrote: matteobp: this is very strange, on USB3.0, on 4.4, on OMV, with FDE, over GbE I get around 80MB/s.
I have never seen this speed, not even in reading! Huh
In the weekend I'll try the latest stretch 0.6.15 - 175 with default  kernel 4.4.103.
I'll check the network performance using netperf with both windows and linux machine, and the USB3.0 local performance with iozone (but if I'm not mistaken it is over 100MB/s).
I can also make a test with Helios LAN test.
Do you need some particular log or output?
Thanks.
I did the test with the jessie OMV 0.6.19 and jessie OMV 0.5.15, using 3 different PC to read from and write to.
One PC with Windows 7, one notebook with Windows 10 and one PC with Ubuntu 16.04 LTS.
All of them have gigabit ethernet, and are directly connected to the router Netgear DGND3700v2 (gigabit ports).
I tried with 2 different ethernet cables to connect the rock64 to the router. The test was done with 1.5GB file.
The average read speed was less than 50MB/s and the average write speed was less than 40MB/s, and there are no significant difference with all of 3 PC.
So i can exclude problem with the "other" PC, and problem with cables.
This is the result of this command
iozone -e -I -a -s 500M -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
Include fsync in write timing O_DIRECT feature enabled Auto Mode File size set to 512000 kB Record Size 512 kB Record Size 1024 kB Record Size 16384 kB Command line used: iozone -e -I -a -s 500M -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2 Output is in kBytes/sec Time Resolution = 0.000001 seconds. Processor cache size set to 1024 kBytes. Processor cache line size set to 32 bytes. File stride size set to 17 * record size.  random    random  kB  reclen    write  rewrite    read    reread    read     write  512000     512   109522   109732   110923   111712    46086    65877                                                512000    1024   108753   109736   109988   110808    63479    78590                                                512000   16384   108623   109206   108038   110314   103154   104457
This is the result of this command (rock64 as client)
iperf -c x.y.z.3 -P 1 -i 1 -p 5xxx -f m -t 10 -T 1
------------------------------------------------------------ Client connecting to x.y.z.3, TCP port 5yyy TCP window size: 0.08 MByte (default) ------------------------------------------------------------ [  3] local x.y.z.15 port 40xxx connected with x.y.z.3 port 5yyy [ ID] Interval       Transfer     Bandwidth [  3]  0.0- 1.0 sec   115 MBytes   962 Mbits/sec [  3]  1.0- 2.0 sec   112 MBytes   936 Mbits/sec [  3]  2.0- 3.0 sec   112 MBytes   943 Mbits/sec [  3]  3.0- 4.0 sec   111 MBytes   933 Mbits/sec [  3]  4.0- 5.0 sec   112 MBytes   936 Mbits/sec [  3]  5.0- 6.0 sec   112 MBytes   942 Mbits/sec [  3]  6.0- 7.0 sec   111 MBytes   934 Mbits/sec [  3]  7.0- 8.0 sec   113 MBytes   947 Mbits/sec [  3]  8.0- 9.0 sec   112 MBytes   940 Mbits/sec [  3]  9.0-10.0 sec   112 MBytes   941 Mbits/sec [  3]  0.0-10.0 sec  1122 MBytes   941 Mbits/sec
This is the result of this command (rock64 as server)
iperf -c x.y.z.15 -P 1 -i 1 -p 5yyy -f m -t 10 -T 1
------------------------------------------------------------ Server listening on TCP port 5yyy TCP window size: 0.08 MByte (default) ------------------------------------------------------------ [  4] local x.y.z.15 port 5yyy connected with x.y.z.3 port 59xxx [ ID] Interval       Transfer     Bandwidth [  4]  0.0- 1.0 sec   108 MBytes   908 Mbits/sec [  4]  1.0- 2.0 sec   112 MBytes   941 Mbits/sec [  4]  2.0- 3.0 sec   112 MBytes   941 Mbits/sec [  4]  3.0- 4.0 sec   112 MBytes   941 Mbits/sec [  4]  4.0- 5.0 sec   112 MBytes   941 Mbits/sec [  4]  5.0- 6.0 sec   112 MBytes   941 Mbits/sec [  4]  6.0- 7.0 sec   112 MBytes   941 Mbits/sec [  4]  7.0- 8.0 sec   112 MBytes   942 Mbits/sec [  4]  8.0- 9.0 sec   112 MBytes   941 Mbits/sec [  4]  9.0-10.0 sec   112 MBytes   941 Mbits/sec [  4]  0.0-10.0 sec  1120 MBytes   938 Mbits/sec
I think there is no problem with disk neither with gigabit transfer.
What is the problem? I don't know. Huh
But reading the forum, I'm not the only one having this problem.
I can't get it to run, the rock64 is refusing the connection.
Thanks.
I will try and run a couple of tests on my 0.6.15 build. 0.6.16 introduced a changed to USB 3 speed to HS. I get around 50MB/s also on read across my network. I ran a hdperf test and the drive performed at over 110MB/s  .  Hope Ayufan can look into this further.
I now have what I hope to be a realtime kernel v4.14.15-rt13 built for a rock64. The last time I tried to do a make install, it bricked the sdcard and I had to start from scratch.
So I'd assume there is an install script that will build a fresh sdcard in a reader plugged into it
Where can I source that script?
Which OS would you recommend for running a webserver + mysql server on? It's for personal (hobby) use for a project at the university. GUI or not does not matter to me.
I'd prefeer something like CentOS or Ubuntu. Just not sure if the packages already exist for easy install with apt get/yum install.
Clean install of Stretch Mate on my ROCK64 and not having much luck getting it configured.
There is no Activities menu so I went to Applications, System Tools, Software and selected Add-ons and Activities Configurator but it never prompts for a PW
Also pressing the Super does nothing
I'm trying to set a static IP and install a VNC server among other things but getting there is very frustrating
I had to add and extra line to /etc/network/interfaces.d/eth0 before I could get route -n to see a gateway.
So my erth0 now has
auto eth0
iface eth0 inet static
address 192.168.nn.2
netmask 255.255.255.0
gateway 192.168.nn.1
up route add default gw 192.168.nn.1
Where nn is the third dotted quad of the address,
But this maybe isn't related? Dunno, but something has changed in stretch.
I am running xfce for a gui.
Can you open a terminal screen?
Can you sudo -i, entering your login pw to become root?
Cheers, gene83
(02-07-2018, 11:20 AM)gene83 Wrote: I had to add and extra line to /etc/network/interfaces.d/eth0 before I could get route -n to see a gateway.
So my erth0 now has
auto eth0
Cheers, gene83
Sorry, I meant Stretch Mate not Xenial.  I've tried every flavor of OS available for the ROCK64 except Android and none of them seem to work properly.  In Xenial Mate, every item listed the Software menu returns an error saying it's not compatible.  I just wish there was something that just 'worked' as well as Raspbian
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,898 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,374 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,064 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,209 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,798 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,827 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,102 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,301 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,168 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,368 09-01-2024, 06:05 AM
Last Post: RaymondDay
