Dual boot options for ROCK64?
#21
@easyfab thanks for catching that! You are correct. I will fix it now.
awesome and clear write-up a1w.ca. I wonder if it would be possible to have nice syslinux-style GUI for it too.
I tried options such as "menu resolution 800 600", "menu with 80" etc.. none seem to work. It seems it support the nice formatting options of a typical syslinux config.
(01-22-2018, 04:55 AM)a1w.ca Wrote: I tried options such as "menu resolution 800 600", "menu with 80" etc.. none seem to work. It seems it support the nice formatting options of a typical syslinux
Ok, will play with it this week and see if I can, at the very least, insert a background into the menu, etc.
Sorry, I completely messed up my last reply. I meant to say it seems it **doesn't support** the nice formatting options.. but yes you're free to try, hopefully you can figure out something. Thanks!
Ah! no worries. Bit of a pity, but I will give it a go nonetheless.
Is it possible doing a dual boot from ssd & emmc without switching among them?
Anyone have update son this?
I was trying to add multiboot / test out of the box Ayufan's options but couldn't get menu to appear for me but increased timeout increased booting time so it must be out there ...hidden.
(05-01-2018, 03:58 PM)S3phi40T Wrote: Anyone have update son this?
I hope you weren't expecting to see it on your monitor, as AFAIK, it's only visible on the serial console, as it should be way too early in the boot process for HDMI and usb keyboard support...
When I'm connected to the serial console, I see a menu similar to this one discussed back in post 8:
mmc1 is current device
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
891 bytes read in 73 ms (11.7 KiB/s)
Rock64 boot options
1:      kernel-4.14
2:      kernel-4.15-rc6
3:      kernel-4.4
Enter choice: 2
2:      kernel-4.15-rc6
Retrieving file: /boot/Image-4.15-rc6
And there is more info here about the boot menu - https://github.com/ayufan-rock64/linux-b...booting.md
  rAudio for Rock64 V2/Pine A64+ shinzuka 12 2,384 07-24-2026, 03:43 PM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 88,960 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,332 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,387 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,418 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,385 11-03-2025, 09:25 AM
Last Post: darkfader
  PXE Boot example? lewis 7 17,155 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  can rock64 4gb ram run entirely on free software? heocb 1 3,448 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,630 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  How to boot an older, working kernel bits 0 2,702 11-01-2024, 04:43 PM
Last Post: bits
