I can not build a Wifi driver in the kernel
https://github.com/ayufan-rock64/linux-k...h/carl9170
私は、このフォーラムのおかげで、私の欲しいWifiドライバーは、ここにあるということが分かりました。
しかし、このドライバーをダウンロードし、ROCK64に書き込み、「make」と実行しても、
「make: *** Notargets. Stop.」
と表示されてしまいました。
助けてください!!
Google Translate :
Thanks to this forum, I understood that the Wifi driver I want is here.
However, if you download this driver, write it to ROCK64, and run "make"
"Make: *** Notargets. Stop."
And it was displayed.
Help me!!
Try
ARCH=arm64 make
状況は変わりませんでした...
悲しい...
Google Translate :
The situation did not change ...
sad...
Can you explain in a bit more detail what you did so far?
  How to boot an older, working kernel bits 0 2,189 11-01-2024, 04:43 PM
Last Post: bits
  Linux 5.15 Kernel - openSuse mark1250 0 2,600 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 12,533 10-22-2021, 05:45 AM
Last Post: kwinz
  Debian build from mrfixit2001 Luke 18 39,895 05-17-2021, 02:35 AM
Last Post: Wizzard
  Debian kernel stuck at 4.4.167 Enig123 5 9,542 12-29-2020, 12:57 PM
Last Post: kwinz
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 19,638 08-31-2020, 01:41 AM
Last Post: as365n4
  mainline kernel sound support Openwrt lucize 2 6,677 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 10,994 04-18-2020, 11:34 PM
Last Post: CameronNemo
  on-board ethernet driver michaelanburaj 0 2,959 03-26-2020, 12:01 PM
Last Post: michaelanburaj
Question alternative browser / seamonkey armhf build? kapqa 1 4,576 03-26-2020, 03:02 AM
Last Post: kapqa
