Rock64 0.6.x ayufan images
#21
How to update from 0.65 to new
0.66 image
rock64@rock64:~$ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
rock64@rock64:~$ sudo apt-get dist-upgrade
rock64@rock64:~$ sudo apt-get install linux-rock64
linux-rock64 is already the newest version (0.6.5).
there is an update file along with the image files on ayufans git
(01-02-2018, 09:46 AM)dkryder Wrote: there is an update file along with the image files on ayufans git
Great but what is this called as there are many under https://github.com/ayufan-rock64/linux-build/releases
& what command do I use to update.
6.6.6 is removed
you can try 6.6.7 or 6.6.8
When Dist-update from bionic-minimal-rock64-0.6.9-160-arm64.img.xz to 0.6.10  get this error.
Quote:Setting up linux-rock64-package (0.6.10) ...
e2label: Filesystem has unsupported read-only feature(s) while trying to open /dev/mmcblk1p7
Couldn't find valid filesystem superblock.
dpkg: error processing package linux-rock64-package (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of linux-rock64:
 linux-rock64 depends on linux-rock64-package (= 0.6.10); however:
  Package linux-rock64-package is not configured yet.
dpkg: error processing package linux-rock64 (--configure):
 dependency problems - leaving unconfigured
Processing triggers for flash-kernel (3.75ev3dev5) ...
Using DTB: rk3328-rock64.dtb
Installing /usr/lib/linux-image-4.4.103-rockchip-ayufan-162/rockchip/rk3328-rock64.dtb into /boot/dtbs/4.4.103-rockchip-ayufan-162/rk3328-rock64.dtb
Taking backup of rk3328-rock64.dtb.
Installing new rk3328-rock64.dtb.
flash-kernel: installing version 4.4.103-rockchip-ayufan-162
Taking backup of Image.
Installing new Image.
Taking backup of initrd.img.
Installing new initrd.img.
Taking backup of dtb.
Installing new dtb.
Errors were encountered while processing:
 linux-rock64
E: Sub-process /usr/bin/dpkg returned an error code (1)
Whats Wrong?
And can this be fixed?
just as an aside, ayufan has said a couple times in the forum that he would prefer opening issues on the github repo since it helps him track issues. another thing i do not think you fully understand yet is these pre-releases are basically untested, non-perfect, first release very alpha type builds. so to show up with what seems like demands for info, instead of reporting the issue in the proper place as more of a fyi to the developer, rather than questions about what the errors are and when or if a fix is coming, might place you as a better community member willing to test, report and help. usually stuff gets fixed when it can and will be ready when it is. if you can not accept that you would be better off just using the latest release rather than these bleeding edge builds.
Question regarding update 0.6.16. How will the change' Limit USB3 to HS mode in u-boot' affect USB performance? Why was this changed? Question for ayufan I guess... Thanks.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,221 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,807 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 96,379 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,032 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,432 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,442 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,932 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,105 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,998 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 117,679 09-01-2024, 06:05 AM
Last Post: RaymondDay
