rock64 opencl version
Hi everyone,
I'm trying to have a linux build with opencl working (clinfo finds 0 platforms).
I am using ayufan's outstanding xenial-minimal-rock64-0.5.15-136-arm64.img.xz.
I even tried getting on the https://github.com/rock64-linux/libmali but it still does not give me the clinfo positive identification.
Anyone care/know how to enable the OpenCL.
Adrian
(10-21-2017, 02:20 PM)decebal Wrote: Hi everyone,
Adrian
I think simply it doesn't work as tried something similar with OpenGL ES & EGL to try and get 2D acceleration with X11.
Libmali just seems to crash out with a seg fault.
I have been waiting for some of the 4.14 kernel improvements to maybe get backported as a whole rake of updates has been happening with https://github.com/rockchip-linux
So apols, dunno but have a hunch currently it could be a no go.
Mali4xx has no capability of OpenCL.
You have yo use Mali6xx series at least.
(10-30-2017, 03:57 AM)nocrash Wrote: Mali4xx has no capability of OpenCL.
Not true, just have to use the standalone neon...
https://community.arm.com/graphics/b/blo...eon-driver
[Edit]
Things are not currently right with the graphics side and neon and the mainline status matrix has been updated with more support for 4.14.
I think there will be a flurry of work with that kernel and some new images to check.
There might be working software but so far I haven't really seen, something that I could call 'work as expected'.
You should be able to start X11 with OpenGL & Glamor acceleration (software) which I think runs in a similar way and has Neon support.
Crashes out with a seg fault and a bit past my limitations.
I haven't seen a working setup for either but haven't looked much at the OpenCL stuff.
Currently I don't think we are utilizing the Neon at all, we don't have a Midgard GPU, but it is better than the current CPU based offering we are using.
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 297 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 4,224 01-24-2026, 04:44 PM
Last Post: ff255
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 11 16,644 12-06-2025, 01:32 PM
  Xen hypervisor on Rock64 tumbleweed 6 10,392 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,605 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,727 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 3,898 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 76,336 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 103,312 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 5,230 03-14-2024, 03:09 AM
