Dual boot microsd/eMMc?
Hi all, I just received my rock64 and I want to use it mainly as a small NAS with OMV installed in the eMMc. Is it possible to have Android on the microSD and using the jumper to have both systems at the same time?
Thanks, greetings
Enviado desde mi MI 5s Plus mediante Tapatalk
(10-06-2017, 02:26 AM)chitenavi Wrote: Hi all, I just received my rock64 and I want to use it mainly as a small NAS with OMV installed in the eMMc. Is it possible to have Android on the microSD and using the jumper to have both systems at the same time?
Certainly;  that's the whole point, really.   The eMMC has boot priority ,  and if the jumper is in place the eMMC clock line is held to ground effectively disabling the eMMC -- if the SD card has a valid image it will boot from there;
Shy
(10-06-2017, 07:18 AM)MarkHaysHarris777 Wrote: Certainly;  that's the whole point, really.   The eMMC has boot priority ,  and if the jumper is in place the eMMC clock line is held to ground effectively disabling the eMMC -- if the SD card has a valid image it will boot from there;
Shy
That's what I suspected, thank you [emoji16]
  Rock64 v2.0 u-boot SPI issues ju0n 0 488 07-05-2026, 11:02 AM
Last Post: ju0n
  Disable MicroSD reader for extra GPIO mxruben 0 12,399 07-27-2024, 10:08 PM
Last Post: mxruben
  Rock64 won't boot luminosity7 10 17,962 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 4,587 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 5,744 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,862 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 4,471 09-18-2022, 02:29 PM
Last Post: mexicanflyer
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 6,676 10-28-2021, 12:20 PM
  Pine Rock64 eMMC lifespan moonspell79 3 6,958 08-19-2021, 06:46 PM
Last Post: bcnaz
  boot hdd usb3 philipe 1 4,848 01-27-2021, 02:12 PM
