Android 7.1 Tablet and TV (alpha, proposal)
Can you explain why below sfdisk parameters specified use the same start position for system, cache and data?
echo "Partition table..."
cat <<EOF | sfdisk "$out"
$((part_position*mbs)),$((boot_size*mbs)),6
$(((part_position+boot_size)*mbs)),$((system_size/512)),L
$(((part_position+boot_size)*mbs)),$((cache_size/512)),L
$(((part_position+boot_size)*mbs)),$((data_size/512)),L
EOF
device/pine64-common/vendorsetup.sh
sdcard_image pine64_android_7_1.img.gz doesn't generate a valid image !
Hi, when I download the 0.2.3 , burn the image with Win32DiskImager on a 16gb SD and insert it in my Pine64 1gb, nothing happens. In other Android releases, at least my TV sees the HDMI connected. Am I doing something wrong? My goal is to use Kodi 17 + HDMI + CEC. Should I use another build?
thanks ayufan always keeping this development UP Big Grin D:
hey its any changes that can u implement the THINGS support in the build .??
[Image: thigs.png]
im trying to upload an app with THINGS code in it but seems that the rom does not have the library in it, so its not working
and due the THINGS support starts on Nougat i cant try it on my android 6 sd
https://developer.android.com/things/sdk/index.html
thanks .!
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
(11-23-2016, 04:58 PM)ayufan Wrote: ...
Download: https://github.com/ayufan-pine64/android-7.1/releases
Hi ayufan.
Unfortunately the android-7.1-pine-a64-pinebook-v0.2.3-r9.img doesn't boot on mine Pine64-1GB Sad
I tried Win32DiskImager and Etcher with same result and what's most weird I found out is that Windows sees microSD as FAT formatted, though if I write working image it sees the card as unformatted.
Could you please help me to figure out what could be the reason?
d;-)
By that time the image rev2 is working well.
https://github.com/ayufan-pine64/android...-r2.img.gz
d;-)
Hi ayufan.
pinebook image is for pinebook, not pine64 board. that's what i read a couple weeks ago,anyway.
All the images that have 'pre-release' written next to them are beta images! The stable ones below are marked with 'release' ... you can use the pre-release images but then you have to check out the sources and submit bug fixes to ayufan too :-)
Hi, I can't get the LCD to work, using the 2GB pine64.
I set screen0 to "lcd" and mode to "screen0" only. When I power up the pine, the LCD lights up a few seconds later then everything instantly shuts off, pine's power led turn off and LCD is totally black. (compiled from clean sources, and the image works correctly on HDMI with screen0=hdmi)
Is there any logging somewhere to see what happens ?
#19
(05-22-2017, 04:01 PM)drich Wrote: Hi, I can't get the LCD to work, using the 2GB pine64.
There are a ton of threads for this. Not only are they sending some updates the kill the build, it also could be something as simple as your power supply and how your attaching it to the board....
#20
My LCD worked fine with the old builds, but I will give a try with 5.1 image to be sure that it's not a hardware fault.
Edit: okay looks like my lcd is defective, I just discovered that I have to touch the GPIOs with my hand to turn on the display, touch-layer is not working at all
Edit2: the ribbon cable of the panel is actually cut on one side, probably the backlight part
  Need help compiling android for pine a64 + YeeticusMaximus22 1 181 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 530,003 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 42,522 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 26,049 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 10,713 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 11,905 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 8,832 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,594 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 351,382 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,297 02-26-2019, 11:58 AM
Last Post: Twistedx
