Android 7.1 Tablet and TV (alpha, proposal)
Based on my work for Android 7.0 (http://forum.pine64.org/showthread.php?tid=2136) I did bump the version to 7.1.
Here's the video: https://goo.gl/photos/1XKM9eGS3vDPFef17
Download: https://github.com/ayufan-pine64/android-7.1/releases
Report all issues here: https://github.com/ayufan-pine64/android-7.1/issues
N.B. Do not update SudoSu - it breaks the installation
What does work?
I see that some things do work, but I didn't really test that.
I did only apply changes of 7.1, compile and do two test runs.
I believe that this build is very similar to 7.0 and has the same limitations.
What does not?
- Definitely not Widevine DRM. So no Netflix.
This is alpha build, so do not complain Smile
If something doesn't work:
- try to see logs (adb logcat, adb shell dmesg),
- try to compile and fix it by yourself,
- when you find solution create a Pull Request for one of this repositories: https://github.com/ayufan-pine64/
How to compile?
https://github.com/ayufan-pine64/local_m...nougat-7.1
You can also see my Jenkins compilation script:
https://github.com/ayufan-pine64/android...enkinsfile
Download:
Install:
The builds are designed to be used with Pine A64 1GB or 2GB on at least 4GB sdcard.
Use Etcher to write images: https://www.etcher.io/
The build automatically resize data partition on first boot to use sdcard space.
LCD:
To enable LCD, edit uEnv.txt from BOOT partition and uncomment:
pine64_lcd=on
HDMI resolution:
Edit uEnv.txt and select one. You can find all supported in uEnv.txt:
disp_mode=1080p60
Ethernet speed:
Edit uEnv.txt and select desired speed, by default it uses auto-negotation.
For example to limit to 100Mbps:
eth0_speed=100
Google Apps:
Android Regular and TV already has Google Apps installed.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
whan i use this it run same as android 7.0
Not sure what you mean.
Releases:
Buy me a Beer
i was using 7.1 & 7.0 problems with Crunchyroll tv app  i use was overscaling in in playback  everything else works perfectly for what i use it for.
now in am using 6.0
Thumbs Up
Hey, thank you so much ayufan! I just noticed this release. I look forward to trying it out myself. You are contributing so much to this community - without you, android wouldn't even be feasible on this device.
Anyways, thanks again!
veronicasmithen03: I do not work more on this one now, this is here for demonstration purposes only Smile
Releases:
Buy me a Beer
(12-15-2016, 07:06 AM)ayufan Wrote: veronicasmithen03: I do not work more on this one now, this is here for demonstration purposes only Smile
So, I assume the effort is still on 7.0 until 7.1 is more "ready" and you were just testing if Jenkins could compile it??
Still, 7.0 should be plenty up to date for most uses.
I still have no idea why 7.0 work fine but 7.0 TV will not take any input devices I have tried.  The drivers should be the same, only with a different GUI.   right?
No. There are differences.
> "if Jenkins could compile it"
Almost there, it is still a new Android version with it's own problems and does require porting.
Toriless: you seem to be answering everywhere claiming that nothing works, which is interesting, because most of what are you describing does work for me Smile
So, something is off, somewhere Smile
Releases:
Buy me a Beer
(12-21-2016, 04:42 PM)ayufan Wrote: No. There are differences.
...but what?  It makes no sense.  USB and the touchscreen work under another OS which would eliminate hardware as the issue.
USB and touchscreen work for me.
  Need help compiling android for pine a64 + YeeticusMaximus22 1 587 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 546,271 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 43,972 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 27,930 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,059 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,315 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,098 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,773 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 363,802 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,503 02-26-2019, 11:58 AM
Last Post: Twistedx
