Power Switch for Pine64 512MB Board
So I ordered a push button switch (which I did not receive as an original backer) as well as the Wifi / Bluetooth module for my board and it finally arrived today. However, contrary to images and instructions I've found online, the holes for the switch seem to be soldered closed. Is this a manufacturing error, or is the 512M board different from the rest? The site indicates that it "does not need to be soldered on to the board. Legs can be inserted then bent to keep in place".
The button is pretty optional (and cheap) for the most part, but it's still very frustrating that I can't use something I ordered and waited on.
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 10,279 10-21-2025, 10:13 AM
  New RockPro64 Power Up Problem enorbet2 7 13,674 10-28-2023, 12:08 PM
Last Post: dkebler
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,357 10-06-2022, 08:46 PM
Last Post: ihab
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,733 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,038 06-17-2021, 05:35 AM
Last Post: kqlnut
  Pinecil power Erincka 0 3,447 03-21-2021, 11:52 AM
Last Post: Erincka
  Session fails to fully start after unexpected power off during initial upgrade Avron 0 3,556 03-18-2021, 11:52 AM
Last Post: Avron
  Power button sdziuba 1 4,443 03-14-2021, 09:05 AM
Last Post: xalius
  PBP won't power. Charge light solid orange/red but turns off. cmicallef 15 24,363 03-12-2021, 07:08 PM
Last Post: cmicallef
  howto power hdd via usb3 on rockpro64 hanscees 2 8,408 06-17-2020, 02:00 AM
Last Post: hanscees
