(potential) work-around for Playstore authentication issue
#31
(09-01-2016, 09:58 AM)MarkHaysHarris777 Wrote: No.  If your time is set correctly, and if your TZ (time zone) is set correctly, and if you're logged into Google and the playstore, you will NOT have this issue.  I have two Android boxes, one playbox, the other I call my play desk, and they both work fine...
I have the timezone set to central (I'm in Houston) and I manually set the time and still had to log out/log in again within the same session.
#32
You need to have your gmail setup and be logged into gmail and the playstore.
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 7,619 11-16-2017, 02:14 PM
Last Post: Skivholme
  Playstore Selections Limited in 7.1 TV CharlieB 2 6,140 10-19-2017, 12:24 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 7,036 08-29-2017, 12:05 AM
  VPN issue on Pine64 pinea64.edison 4 10,409 06-27-2017, 12:25 PM
Last Post: milkaca
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 19,841 06-02-2017, 01:32 PM
Last Post: Bob123456789
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 11,240 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,176 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 9,867 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,461 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 3,973 09-11-2016, 06:29 AM
Last Post: ameth
