buring image with 'dd' on linux doesn't work (Solved)
I'm using Android 5.1.1 Image Release 20160711 [v1.2.6].
I notice that if I burn this to the sd card with the following command, it doesn't work. pine64 does not boot. Nothing comes up on the screen.
dd bs=1M if=android-ver5.1.1-20160711-pine64-8GB.img of=/dev/mmcblk0p1
umount /dev/mmcblk0p1
Has anyone had success with burning the image using 'dd' on linux? Can you please share the exact command you used?
(10-16-2016, 11:46 AM)mathiraj Wrote: I'm using Android 5.1.1 Image Release 20160711 [v1.2.6].
You cannot write the image to a partition ( your dd command above is not correct ).
Try the following:
sudo dd bs=4M if=android-ver5.1.1-20160711-pine64-8GB.img of=/dev/mmcblk0
also
you must 'unmount' the volume 'before' you run the dd command. If the volume is mounted the dd write will not work either.
Thanks for the reply. Your command made it work.
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 7,701 11-16-2017, 02:14 PM
Last Post: Skivholme
  Does snapchat work on pine64 with android? user875545 1 7,107 08-29-2017, 12:05 AM
  Mac doesn't detect USB connection with PineA64+ 1GB using LCD touchscreen magna_shogun 0 3,496 08-28-2017, 03:52 AM
Last Post: magna_shogun
  Reducing Android Image download size. KPhillisJr 4 13,404 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,654 07-18-2017, 08:49 AM
Last Post: eclay
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,525 05-05-2017, 01:50 AM
Last Post: Quezbeme
  android image & sd card size problems tomarneson 11 28,307 01-24-2017, 05:31 AM
Last Post: ayufan
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 11,358 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,593 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 9,964 10-28-2016, 07:41 AM
Last Post: jkmooney
