remix os Phoenix CARD and Win32 Problem
Hi i dont work phoenix and win32.
i try  phoenix error message " Script not found "
i try win 32 write succesful.But not burn microsd card.
My Os : windows 10
Microsd card : Samsung 32GB
image : remix os 32gb version.
How can i this problem ?
Pls Help me ?
hi pilgrimage, visit us on the irc channel for help live. We can assist you much easier in the irc chat root , and you will not be so frustrated. Look forward to seeing you there
Use the irc addresses below:
(08-10-2016, 10:50 AM)pilgrimage Wrote: Hi i dont work phoenix and win32.
My Os : windows 10
Pls Help me ?
See this thread.
The Script Not Found error occurs due to trying to burn a DD image with PhoenixCard.
If you are going to use PhoenixCard to burn RemixOS, download this image instead.
I tried to record the image file remix-v2.0-20160718-pine64-8GB.img in card micro sd 8 gigas, using the application Win32DiskImager with Windows 10
Result: no recorded file appears on the card. Why?
I do not know how to start my Pine64.
Could you help me?
Thank you
I followed these steps
INSTALL remix-v2.0-20160718-pine64-8GB.zip
1.) Download remix os image / android-ver5.1.1-20160711-pine64-8GB
2.) Extract it using winrar
3.) Write image to your sd card using Win32 Disk Imager (is not recorded )
4.) Insert card into Pine 64
5.) Power on Pine64 unit
(08-17-2016, 02:11 AM)Tomas Gomez Sierra Wrote: I do not know how to start my Pine64.
Tomas,
To 'start' your pine, you should simply need to connect the power - i.e. plug in the microUSB lead into a suitable power source. This CANNOT be your computer USB port, it will not provide enough power. You need to use a 5v 2A(more than 2A is fine) power adapter with a micro usb connector (or a microusb lead if your adapter has a USB socket). When you connect the power, a red light should come on near the micro usb port on the pine64.
When you say it is not recorded, do you mean there is an error, or does Win32 Disk Imager take several minutes to write the image to the micro SD card? If you mean when you look at the microSD card with windows explorer, that there is nothing there or windows wants to format the drive (do not click yes!!!), then that is normal, as Windows won't know how to read the Android filesystem.
  New RockPro64 Power Up Problem enorbet2 7 14,144 10-28-2023, 12:08 PM
Last Post: dkebler
  dependency problem cerno 4 9,251 05-07-2021, 08:18 AM
Last Post: cerno
  How to boot from SD card on pinebook pro linux123 3 10,551 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,230 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,299 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,477 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 305,462 03-03-2020, 11:34 PM
Last Post: siyatalerja
  First Boot HDMI/USB problem reefer 1 7,464 11-18-2018, 10:32 PM
  ethernet lan speed problem android fulltone 0 4,063 04-23-2018, 01:47 AM
Last Post: fulltone
  eMMC card on adapter Malmgren 8 19,149 03-20-2018, 11:14 AM
Last Post: Malmgren
