Android 5.1.1 Image Release 20160711
(07-15-2016, 02:28 PM)Boring Wrote: Updated android using phoenixcard. It worked well and android is running smoothly now.
However OTA didn't work for me. Maybe me previous version of Android was too old?
Or it was a rooted image? My understanding is, based on other posts I've read, a rooted image won't OTA update.
Yes. This information is also there on the main Pine64 wiki page when you download an image:
"online update (OTA) only work when the build still not root."
Source.
(07-15-2016, 12:26 PM)Pepe Wrote: Oh... Are you kidding me? It cost $150? Fuuuuu*k.  I want it, too! Smile
I missed that item.  I only saw $15 OFF Pi3.
Source.
Yes, that's where it was.
So I might be missing something real simple here, but what is the upgrade process for a rooted image without having to start over with a clean image every time?
(07-14-2016, 04:43 PM)clarkss12 Wrote: I did try that Win32 imager first, installed OK, but would not run.  Also, tried the 32gig verion, but like others, the SD card was too small.  I was trying with the 32gig version with my 32gig card, using Win32 disk imager.  But the Phoenix app works great for me.
I have the same error with my 32gb card and the 32gb image. But in my case, the Phoenix card says thas "no script file" and I can't do anything.
Do you mean a script not found error? That is due to trying to burn a dd-type image using PhoenixCard, which will not work.
Please see this thread.
Source.
That I do not know, unfortunately. I assume that you do need to start over each time.
Source.
Thanks, Ghost. My image is it, the one from the main page, 32Gb, like my class 10 card.
Online update (OTA) only work when the build still not root? Clean image? I still not understand. If Phoenix Card can't burn the image (because is not for it) and other softwares, like Rufus and Win32Imager says "no space in your card", what can I do. Which one I need do choose?
(07-15-2016, 04:43 PM)DonFL Wrote: Or it was a rooted image? My understanding is, based on other posts I've read, a rooted image won't OTA update.
Source.
Hi at all,
I have partially solved by installing the DD 16 gb version in Sd card 32 gb (SanDisk class 10) and works well. Phoenix is wrong to my pc. Initially it would not connect to the internet via Ethernet but it was (good) with Wifi. After several flares now it's OK to the Ethernet port and am using Netflix even with a Powerline TPLINK. Do you think I can recover unused space of Sd with a partitioning program?
#19
(07-16-2016, 01:18 AM)Ghost Wrote: Yes. This information is also there on the main Pine64 wiki page when you download an image:
Source.
Hi at all,
I didn't succeed in using gparted everytime I got an error that some partitions were overlapping. However the Android image is working perfectly.
#20
The only way I have found to create a working sd card was to burn a 32GB image to a 64GB card....
  Need help compiling android for pine a64 + YeeticusMaximus22 1 719 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 549,957 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 44,403 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 28,232 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,116 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 12,405 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 9,165 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 5,816 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 368,468 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 6,547 02-26-2019, 11:58 AM
Last Post: Twistedx
