Can't get past the "Allwinner/Android" screen
HI all,
I've read probably have or more of the thread and didnt see this issue unless I miss that thread.
I watched the install video and also checked that my sd card has no error.
My issue is that I'm was able to load one of the new android img onto my sd card.  before it would do the "dos" text type error message on the screen.  With the new img I would get the card to "boot" to a screen Allwinner and Android logo screen and get stuck there.  I let it have enough time to unpack in case the first boot took awhile but after 4+ hours (went to sleep) its still there on that screen.
Pine64+ with 2 gbram- only has the sd card, power supply from pine64, and a direct hdmi connected to the TV.  I also trade this with the img for the touch screen and got the same issue.
I have also tried to use RemixOS and Debian Mate but only got a black screen with these 2 OS.
Is the card DOA in that something works but bricked or something?
(07-10-2016, 01:00 PM)d34532 Wrote: HI all,
Try a different microSD and find out.
Remember that different operating systems may require different burning methods.
Forgot I also tried 3 different microSD card and same result. Used the burning method that was required for each OS burn method and same issue.
  7" LCD Touch Screen Panel IanJames 0 3,529 04-01-2020, 04:40 PM
Last Post: IanJames
  User Screen Black After Changing Power Settings 0b51Gekko 2 8,086 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
Question Do I need a touchscreen to run Android? chrbar 3 8,600 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 4,035 04-23-2018, 01:47 AM
Last Post: fulltone
  Rock64 + 7" touch screen naviathan 2 7,580 09-28-2017, 09:01 AM
Last Post: naviathan
  No sound on Android 6 or 7.1 reeno 0 4,310 07-29-2017, 06:31 PM
Last Post: reeno
  7" Screen - Does it work with Debian abasel 1 6,253 07-26-2017, 05:44 AM
Last Post: pfeerick
  RESOLVED - LCD screen not working, HDMI does asuras 10 24,524 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI-VGA adapter. Blank screen. trumad 10 27,814 03-05-2017, 03:17 AM
Last Post: pfeerick
  Does ubuntu img support the touch screen kingsing2 4 11,919 01-29-2017, 02:41 PM
Last Post: greglarious
