(potential) work-around for Playstore authentication issue
LOL @Stilton Helmet. No blame is needed.
For affected users, it doesn't appear to be a settings issue. No matter what the settings
Are all Android/Remix users affected? Or do we have something in common? (See my signature for my setup.)
(Sent via Debian on Pine64+.)
NexusDude of Central Texas
  • Setup: Pine64+ 2GB, On/Off button, RTC battery, 5V fan, LG 1.8A power adapter, Cat6 Ethernet, HDMI to TV, USB keyboard & mouse, SanDisk Ultra mSD "32GB" (28.7GB). Using Win32DiskImager.
  • Best OS experiences: Debian XFCE >> Android Lollipop > the rest
Indeed NexusDude, @Stilton Helmet no blame is needed as we are all just trying to get to the bottom of this and find a viable temporary solution.
My solution was to uncheck the Sync for apps and check it again, without even exiting the Google Play app. Worked right away for me.
Hope this helps!
Edit: (to specify)
I went into Settings, Accounts, Google, my email, i disabled App Data sync, and then enabled it again.
(06-26-2016, 09:57 PM)CypherColt Wrote: My solution was to uncheck the Sync for apps and check it again, without even exiting the Google Play app. Worked right away for me.
Hope this helps!
Edit: (to specify)
Im sure it will help someone, thanks Smile
I was pretty worried about this not working for me. My board came in yesterday, had it running in a few seconds. Didn't have any issues using the Play store (apart from typing shit in with the crappy media remote)
PINE A64+ w/ 2GB SDRAM, 8GB MicroSD Card, Basic Media Remote, Acrylic Open Enclosure, Wifi/Bluetooth Module, 5V 2A Power Supply.
Backer number #26,231  + KS Funded Jan 16, 2016 + Backerkit funded March 10, 2016
STATUS: SHIPPIED 6/21, RECEIVED 6/27
This continues to be an issue for my Pine64.
For my Pine64, it occurs consistently, sort of.
  • Affects all Android images -- rooted, so-called "un-rooted", RemixOS
  • GP Store will always work, initially, upon booting for the first time
  • GP Store will eventually stop permitting app downloads and app rating submissions. Even if it's working now,  give it time...
  • Once it fails, it continues to fail, until you apply a work-around fix, or re-image.
  • Once a workaround fix stops working, it continues to fail. You must try a different fix, or re-image.
(The DD images of Android all test as rooted.)
What varies:
  • The length of time that GP Store works. When you boot for the first time, or succesfully apply a workaround fix, it will work... but eventually it stops. You may get downloads & rating submissions working for hours, or only seconds. Typically, you can get in a few installs, while it's working, before it quits again. You many only get 1 install in, though, or none at all. In a one hour session of Android, you may apply fixes several times, without rebooting.
  • Sometimes, workaround fixes stop working.
  • Pop-up vs. Notification. How the app informs the user of failure varies. A pop-up error message likely mentions DF-DLA-15. An Android notification always mentions authentication failure.
  • Multiple notifications vs. 1 notification maximum -- sometimes, you must clear the notification to be informed of future errors; other times, you can get multiple notifications
  • Various fixes, sorted by speed:
  1. Settings / Accounts / Add New Account / Google
  2. Settings / Accounts / Add New Account / Google / enter gmail of existing Google account
  3. Settings / Accounts / select account / Remove Account / Add New Account / Google / enter gmail of account you just removed
  4. Clearing GP Store and GP services caches, rebooting
  5. Wiping the Dalvik partition, rebooting
  6. Reimaging your microSD card, booting
Other things I've tried, that never helped or seem unrelated to this issue:
  • Gmail accounts with 2-step verification, vs. those without
  • Using only a single Gmail account, vs. using multiple Gmail accounts
  • Using Gmail accounts with Play Store credit, vs. those without a payment method
  • Rebooting
  • Using other images of Android
  • Using a time app to document time clock differences
  • Turning account syncing off/on
  • Various power adapters
What I have not yet tried:
  • Heat sinks / fans / cooling my house more
  • RTC battery
  • Shorter Cat6
What I've had trouble trying:
  • Wi-fi dongle
  • Mock Location -- there doesn't seem to be a way to set this
  • Using a time app to reset the time from NTP
Few have voiced their frustration on pine64.pro, which seems odd, considering the various threads on this issue. Maybe they didn't want to bother registering a new ID there?
Since I did the account reset and have the onboard clock battery I've not had this issue back btw.
(07-05-2016, 12:54 PM)Danja Wrote: Since I did the account reset and have the onboard clock battery I've not had this issue back btw.
That's great.
After I installed a 3V battery to power the RTC, and doing Settings / Accounts / New Account / Google, the authentication issue was gone... for about 8 hours. I was just about to report my success, when it returned.
Angry
The Clock Sync app shows that the clock gets off sync with NTP, despite the RTC powered by 3V battery.
My testing suggested that this isn't a clock issue, but I'm not sure now. Maybe it's a clock issue, plus something else? I'll use Clock Sync and the RTC battery together, to try to keep my Pine's clock synchronized with pool.ntp.org. We'll see...
#19
That's great.
Angry
I plan to make a new Android code release on next two days with GSM 5.1r4 package, and this include latest App Store code. hopefully this can resolved the Play Store mystery.
#20
(07-07-2016, 11:39 AM)tllim Wrote: I plan to make a new Android code release on next two days with GSM 5.1r4 package, and this include latest App Store code. hopefully this can resolved the Play Store mystery.
I would bet this definitely will fix some issues. Is there any documentation on how to build the android os from scratch. I would love to check out some stuff as well. Is there a git somewhere?
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 7,691 11-16-2017, 02:14 PM
Last Post: Skivholme
  Playstore Selections Limited in 7.1 TV CharlieB 2 6,194 10-19-2017, 12:24 PM
Last Post: Luke
  Does snapchat work on pine64 with android? user875545 1 7,099 08-29-2017, 12:05 AM
  VPN issue on Pine64 pinea64.edison 4 10,486 06-27-2017, 12:25 PM
Last Post: milkaca
  No Intenet Access Need Help Diagnosing Underlying Issue Bob123456789 10 20,028 06-02-2017, 01:32 PM
Last Post: Bob123456789
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 11,342 12-11-2016, 05:57 PM
Last Post: Luke
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,538 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 9,950 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 8,524 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 4,003 09-11-2016, 06:29 AM
Last Post: ameth
Users browsing this thread: 8 Guest(s)
