Android and Ethernet
#51
(06-19-2016, 07:45 AM)tllim Wrote:
(06-19-2016, 03:59 AM)g_t_j Wrote:
(06-17-2016, 05:13 PM)tllim Wrote: We are currently getting the latest PHY driver from Realtek (PHY chip vendor) and check whether this will resolve the Gbit issue or concern. In our own lab, the Gbit seems works fine and we are that users seems getting no good results. Hopefully, the new PHY driver integration will able to resolve this outstanding issue. This takes 2-3 week for release.
TL Lim,
Any other updates with the coming image?
Will Skype calls work? With current UVC driver Skype crashes and I suppose the specific driver needs refinement.
What about compatibility with 720p monitors? USB audio capability?
The compatibility of the 720p will be include on next release. The others items still not yet look into due to we rather focus on bring up Marshmallow build first.
I guess you already made the same discoverys as I did regarding the Android + Ethernet issues, but i still want to point out to the Thread i opened up to show what I managed to discover myself http://forum.pine64.org/showthread.php?tid=1358
Basic conclusion:
- The ethernet will not work without the WiFi module attached even though it's not turned on. It might work for 1-3 seconds and get the Time from an NTP server but after that you are lucky if u get even one second of connectivity.
- If the WiFi module is attached the ethernet works fine but as everybody already mentioned in 100mbit.
- It looks like if WiFi module is not attached the Pine is still looking for it trying to initialise it.
#52
I had the same issue on the first boot. After restarting ethernet worked fine but its too slow..downloading youtube app from playstore took more than 10 mints..so wondering if this is the current state of things wrt ethernet on android or its only happening with my device.
I dont have Wifi+BT module and dont have Gigabit on my router, just 75 Mbps. I downloaded the android image from the wiki.
Thanks.
#53
(07-02-2016, 10:58 PM)curiousgally Wrote: I had the same issue on the first boot. After restarting ethernet worked fine but its too slow..downloading youtube app from playstore took more than 10 mints..so wondering if this is the current state of things wrt ethernet on android or its only happening with my device.
Thanks.
Yeah appearently additional issues occur when the Ethernet connection has the choice between gigabit and mbit connection. Some people already told me to slow down the connected port. Haven't tried it yet.
#54
Hey everyone, i have the 2gb model and the only way i have been able to get ethernet working is by routing it through 2 power line adapters with 100 ports.. Im pretty certain its the gigabit issue people have mentioned but my router doesnt have the option to drop down to 100 mode.
I can also use a cheap usb to ethernet adapter but it operates at 6mbit which is terrible as it averages 70kbs
Hope this gets fixed soon
[Image: 20160705_152014.jpg]
#55
Issues here with Android and Ethernet on my 2gb Pine64 as well.
Sometimes I get very slow internet and sometimes I don't get any connection at all.
Some apps also don't recognize the Ethernet connection as an internet connection and don't want to use it. They rely on wifi.
Any solutions yet? In the mean time, I've ordered an extra SDHC micro SD card and I'm gonna play around with other OS's to get it to work.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,678 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 609,194 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,322 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,109 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,736 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,324 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,607 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,777 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 410,173 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,551 02-26-2019, 11:58 AM
Last Post: Twistedx
