How often do you flash a new bios to your x86 box?
ie, why update a working uboot?
If you flash a new image to emmc, then you get a new one, will or no
Smart to save a working uboot 1st (before flashing), the 1st 16M, and deal with mbr- partiton table
Anyway, to the point........
Since nothing in the 1st 16M is mounted, you don't have to disable emmc
Just get a uboot package and flash away
If you don't have a booting nvme, manjaro has a BSP uboot,, (and I would bet it would boot SD's)
uboot-pinebookpro-bsp-1.5-7-aarch64.pkg.tar.xz
Too bad there is not an "approved" uboot to flash on SPI or no uboot ratings page
BTW, this has a extlinux.conf in it that is ONLY suited for 2 partition installs, that is a separate boot partition,
ark often will 'pull' it apart so you can get out idbloader, uboot, trust OR edit extlinux.conf if needed BEFORE reboot
Most manjaro installs are 2 partition
Things are slowing down to a halt in pbp country. Any news?
(04-16-2024, 12:49 AM)Tazdevl Wrote: Things are slowing down to a halt in pbp country. Any news?
About 2 years now & mine is still working fine; only had to glue the feet back on & lube the hinges as a precaution.
I’d say the lack of posts are good news, as most of us have any issues worked out; the common problems & solutions have already been well documented.
This year I added Arduino IDE, so I can setup the boards on-site and other than that, nothing new here.
PinePhone, Pinebook Pro & PineTab2 owner.
No gnews is good gnews. Software has matured, even if Linux mainline is passing the PBP by.
Mine are all still working and in daily use. My 2020 model oddly works better than my 2023 model. I suspect the heat transfer pad might not be working. Probably my fault for not keeping the bottom secure. But the reason the bottom isn't secure is that the plastic is breaking like a first-batch PBP. I may need all new casework soon.
NetBSD 10 really makes the PBP shine.
:wq
(04-16-2024, 07:29 PM)KC9UDX Wrote: No gnews is good gnews.  Software has matured, even if Linux mainline is passing the PBP by.
Sometimes older models just age better. NetBSD 10 really brings out the performance, even on those first-batch PBP quirks.
  Pinebook Pro for sale rfm83 0 451 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 4,942 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 6,976 08-02-2025, 08:55 PM
  Pinebook problem meghancordo 1 4,281 07-24-2025, 07:28 AM
Last Post: mikehenson
Question Printing and scanning documents with pinebook? Www 0 3,795 06-28-2025, 01:25 AM
Last Post: Www
  Pinebook Pro in EU for Sale - €90 jan_vdk 4 7,223 06-19-2025, 02:14 AM
Last Post: shelfaberrant
  Use SD to install new OS over pinebook debian Rudy558 10 24,425 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 4,804 02-05-2025, 03:56 AM
Last Post: waylonwesley
  Pinebook Next !spekulation! Surehand53 2 5,798 01-23-2025, 11:49 AM
Last Post: Surehand53
  Pinebook Pro wants a PIN for my bluetooth mouse ColoBill 1 4,317 01-19-2025, 04:38 PM
Last Post: ColoBill
