Pinebook pro won't boot after bootloader installation
Hi guys, i bought today a used pinebook pro and i recived it with stock majaro and towboot. i tried to update towboot using
dd if=Tow-boot.spi.bin of=/dev/mtd0
i know it's not the best way to do that but i did it and reboot. Now my pinebook doesen't boot (no light. no sign of life i tried to disable eMMC and boot both manjaro and tow boot from SD card but it doesen't show sign of life and i really don't know what to do. Any help? Big Grin
You'll want to follow the instructions laid out on this wiki page to clear the SPI: https://wiki.pine64.org/wiki/Pinebook_Pr...e%2C%20you or this forum post: https://forum.pine64.org/showthread.php?tid=11976
I'd suggest to make an SD for installing tow boot with this img: https://github.com/Tow-Boot/Tow-Boot/rel...007.tar.xz
following the instructions provided here to install it: https://tow-boot.org/devices/pine64-pinebookPro.html
Has the issue been resolved? It seems that I am encountering the same problem.
why i can't to reply?
(08-20-2024, 08:35 PM)Fglick Wrote: Has the issue been resolved? It seems that I am encountering the same problem.
This "problem" is an inherent side effect of the way the PBP works. Do follow the link from tophneal's post.
:wq
  Boot Order in Pinebook Pro food 15 19,737 Yesterday, 01:09 AM
Last Post: NorrisFByrd
  Window Maker Live for Pinebook Pro vajak 9 6,700 05-20-2026, 06:55 AM
Last Post: vajak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 14,339 08-09-2025, 06:53 AM
Last Post: Sb2024
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 4,859 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 12,635 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 20,651 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 17,970 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 10,466 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 11,747 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 165,595 12-08-2023, 11:25 PM
