openSUSE for Pinephone
#71
(11-27-2021, 08:31 AM)flembcke Wrote: I have finally installed Posh on my pinephone.
Everything seems to work right.
Rotation is upside down, any tips on how to fix it?
Telegram can not receive the code. Any ideas how to make it work?
Do you mean you aren't receiving the SMS code from Telegram? If so, that has happened every time I set it up on the PP. I would recommend having an account on your desktop then instead of sending an SMS (which never comes through), it will send a code to the other Telegram client.
Thanks for the reply.
it does not seem much maintained ;(
I tried but autorotate turns the screen 90° to the left of what it should, and connection to nextcloud failed somehow.
Had the same issue with Telegram (on Manjaro Phosh, but it looked and did the same on Mobian or some other as well), and the point is that it's near impossible to create a new account without an old one. It just won't send the verification code as a SMS, it sends to an existing Telegram instance. So creating it with my phone didn't work, wife's didn't work (no Telegram either), daughter's did (has Telegram). But then I had her identity.
So I had to create a new account within this clone of her identity, which meant another security code. Nice touch is that this time I didn't have to retype it, the confirmation went instantaneously and I was finally me. Daughter was also me for a while... Then repeated the process for my desktop (repeated me, on Mint) and wife's laptop (also Mint, separate account). That works.
Daughter also had to do something on her Telegram to make sure she's not me and to revert to her original account.
So it won't grow from seeds, only by cloning and then identity change.
OpenSuse seems a tad more reliable with plasma mobile, compated with Manjaro, which is currently not working well. However, after update, there is not enough kernel allocated memory or it will not boot at all ;(
after flashing again it seems to work, even connected to nextcloud, but does not show any contacts. Very nice to watch boot or update in verbose.
  asterisk or FreePBX on pinephone? vanja 0 1,042 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 26,094 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,399 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 250,965 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 237,128 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,541 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,937 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 73,527 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,398 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 83,851 07-26-2024, 10:35 PM
