firmware update 1.11 > 1.13
I have tried to update my sealed PineTime from 1.11 to 1.12 and 1.13, using nRF Connect.
I followed the istructions here:
https://wiki.pine64.org/wiki/Upgrade_Pin...Time_1.0.0
No luck, though. The watch still runs on 1.11.
Am I doing anything wrong? Thanks.
When you flash the firmware for 1.12, you need to go to the "firmware" settings menu, and click "validate". Otherwise it will reset to the previous firmware if it resets.
Gary
(08-25-2023, 08:29 AM)GaryM Wrote: When you flash the firmware for 1.12, you need to go to the "firmware" settings menu, and click "validate".  Otherwise it will reset to the previous firmware if it resets.
Gary
Thanks Gary,
here are some handy guidelines to upgrade the firmware from an Android phone.
1. get the asset from repo : https://github.com/InfiniTimeOrg/InfiniTime/releases
2. download and install gadgetbridge on a smartphone : https://f-droid.org/packages/nodomain.fr...getbridge/ (or use googleplay)
3. Pair the pinetime with your smartphone
4. Select file installer in your device menu and search for the zip of step 1
Better have both your smartphone and the watch properly charged before proceeding.
  Need help with updating firmware on brand new watch sabersoul1217 0 1,033 07-12-2026, 07:05 PM
Last Post: sabersoul1217
  Stuck in OTA update mode mark1250 4 9,002 06-01-2023, 10:06 AM
Last Post: feketej
  Update of new watch consistently fails bitreaper 5 10,187 06-01-2023, 02:29 AM
Last Post: feketej
  Can't flash firmware, out of options kj6epl 4 7,700 08-27-2022, 11:28 AM
Last Post: monto
Question Which companion apps work best for flashing firmware and pairing/syncing w/ Pinetime? danimations 0 4,427 03-28-2022, 08:22 PM
Last Post: danimations
  Update problems FutureBucket 2 5,769 08-29-2021, 06:34 AM
Last Post: wibble
Question Update to 1.3 Infinitime and other questions? bceverly 2 6,216 08-18-2021, 06:03 PM
Last Post: james8880
  After 0.7 -> 1.0 update cannot connect bluetooth piner67 2 6,177 06-21-2021, 01:39 PM
Last Post: piner67
  minor instructions update(s) D4rkh0rs3 0 2,804 04-11-2021, 01:13 PM
Last Post: D4rkh0rs3
  Hanging on PINE TIME screen - UPDATE now just blank andystratton 0 3,215 01-22-2021, 04:45 AM
Last Post: andystratton
