Update problems
Edit: my bad guys, I found the issue: https://github.com/JF002/InfiniTime/issues/374 I'm going to leave the post here for other who are like me and will come here first.
I got my sealed pinetime awhile ago and I'm wondering if anyone has the same problem and was able to fix it.
I believe it came with InfiniTime v.1.0 and I found and updated using the dfu zip from here. https://github.com/JF002/InfiniTime/releases/tag/1.1.0
The first time it failed, it lost the connection to the watch and everything seemed fine so I tried a second time. This worked without issue and I was on v1.1. Then 3 days later I noticed that the watch wouldn't connect to my android phone with Gadgebridge v0.57.0 from F-Droid. I held the only button and the watch rebooted. Upon reboot the watch booted with v1.0.
Now no matter what I do I cant get the update to work, it just says "Element cannot be installed". I've deleted the Gadgebridge app and tried again, rebooted the watch phone, tried plugged in, not plugged in, etc.
I waited for the pineTime to be "released" so I could be an end user so I don't really want to open it up or solder anything, though I'm willing to. Do you guys have any further suggestions as to what I can do to get back on v1.1?
Thanks!
(06-01-2021, 07:20 AM)FutureBucket Wrote: Edit: my bad guys, I found the issue: https://github.com/JF002/InfiniTime/issues/374 I'm going to leave the post here for other who are like me and will come here first.
Thanks!
Did you get any luck in the end? I got into the same trouble.
That was a bug in GadgetBridge 0.57.0 that has since been fixed.
https://codeberg.org/Freeyourgadget/Gadg...ssues/2304
  firmware update 1.11 > 1.13 aletn 2 4,985 08-25-2023, 10:57 AM
Last Post: aletn
  Stuck in OTA update mode mark1250 4 9,143 06-01-2023, 10:06 AM
Last Post: feketej
  Update of new watch consistently fails bitreaper 5 10,324 06-01-2023, 02:29 AM
Last Post: feketej
Question Update to 1.3 Infinitime and other questions? bceverly 2 6,315 08-18-2021, 06:03 PM
Last Post: james8880
  After 0.7 -> 1.0 update cannot connect bluetooth piner67 2 6,278 06-21-2021, 01:39 PM
Last Post: piner67
  Connection Problems LinuxMathGuy 0 2,830 05-05-2021, 02:01 PM
Last Post: LinuxMathGuy
  minor instructions update(s) D4rkh0rs3 0 2,839 04-11-2021, 01:13 PM
Last Post: D4rkh0rs3
  Hanging on PINE TIME screen - UPDATE now just blank andystratton 0 3,261 01-22-2021, 04:45 AM
Last Post: andystratton
  bluetooth firmware update pjsf 2 7,405 10-16-2020, 02:19 PM
Last Post: Avamander
