Phone Attitude(Device orientation)
I am having trouble finding any sources online about how to obtain the device orientation. If anybody has any knowledge about any libraries or maybe some global value that tracks this.
I am trying to modify this compass app https://gitlab.com/lgtrombetta/compass/ to allow compass to function when in any orientation(not just with your phone flat).
The accelerometer readings are under /sys/bus/iio/devices/iio:device*/ where * stands for an integer depending on the kernel being used. The correct device is the one having an in_accel_x_raw file (and several other similar files, all giving you accelerometer readings if you cat them).
I was hoping there might be some kind of global value that has been through a filter combining the gyro and accelerometer. Maybe the one the OS uses for screen rotation?
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 50 64,051 10-13-2025, 07:46 AM
Last Post: Habbytm
  Guide to Suitable Phone State Borealid 19 27,253 09-18-2023, 07:00 AM
Last Post: robocone
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 6,439 02-18-2023, 06:14 PM
Last Post: fxc
  [Mobian] No return from locked phone arno_nuehm 1 3,095 02-06-2023, 07:57 AM
Last Post: arno_nuehm
  Phone shuts down unexpectedly Hobgoblin 3 5,298 12-20-2022, 01:11 PM
Last Post: Fish
  Sound completely gone with Mobian in Phone Call configuration EwigeBlumenkraft 2 4,649 11-11-2022, 09:18 PM
Last Post: apink
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 2,630 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Outgoing audio in phone calls gone linuxfreedom 6 9,519 10-25-2022, 08:40 PM
Last Post: apink
  Phone wont turn on with any SD Card inserted Ausfaller 3 6,306 07-21-2022, 10:20 AM
Last Post: Ausfaller
  PPP Phone rings with constant vibrate - turn off vibrate henrythemouse 0 2,248 05-16-2022, 03:59 PM
Last Post: henrythemouse
