PineTab 2 Login Failure
I just received my PineTab2 and I'm disappointed that I cannot successfully log in.  I booted it up and tried logging in with the default password, but the screen freezes.  I tried this several times before deciding to download the DanctNix Arch Linux image from the PineTab2 wiki.  I followed the instructions and flashed the image to an SD card with Balena Etcher.  I then connected the included USB to UART connector with the switch in the On position and the newly flashed SD card inserted in the PineTab2.  From there my experience differs from what is in the wiki.  Upon booting, I get the PineTab2 Factory Tool screen.  One of the menu options is to Flash OS to eMMC.  I tried that and it appears to flash the OS image.  When I try booting the tablet up without the SD card, I get the same results.  Log in with the default password and the screen freezes.  Not sure what else to do.  I would appreciate any help.  Thanks
Never mind my last post. I finally was able to log in. I guess flashing it a fourth time was what worked.
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 1,112 03-23-2025, 05:25 AM
Last Post: bartgrefte
  PineTab 2 login screen rotation fix chzbacon 11 12,242 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 5,860 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 3,512 12-13-2023, 08:11 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 5,346 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 10,600 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 41,022 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab Mobian bcnaz 150 206,867 04-26-2022, 11:58 AM
Last Post: thomzane
  Xmonad on PineTab Telefza 0 2,549 06-24-2021, 04:04 AM
Last Post: Telefza
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 6,107 04-30-2021, 06:52 AM
Last Post: thomzane
