[Mobian] : Battery consumption and OS compatibility
I have bought a pinephone and the battery consumption is too high.
As i good understand, pinephone have a SoC AllWine A64 and that's why it drain a lot of battery and warm.
The advantage of this SoC is good supported linux mainlines.
With the pinephone pro, the Rockchip RK3399S SoC is an ARM. In theorical, it drain less battery.
It's right ?
What is the level compatiblity of pinephone pro with Mobian OS ?
-linux mainlines
-basic features
-app
Thank a lot for your feedback
The Allwinner A64 is also an ARM SoC. The PinePhone Pro's SoC actually drains more battery. But it is also significantly faster.
This doesn't directly address your question, but it might help you out.
I'm an electronics engineer who knows how to bench test batteries.  The one supplied with my phone tests at slightly over 2000mAh, so I ordered a genuine Samsung EB-BJ700BBU from Amazon, the one that the PinePhone wiki describes as "a tight fit".  It is a little bit tighter than the originally supplied battery, but nothing to get excited about, and it bench tests at slightly over 3000mAh ... I'm quite happy with it.
***   Don't be a minion in the (i)droid army   ***
  Experimental Mobian kernel patch for extended battery life teekay 15 17,191 10-27-2025, 08:43 AM
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 21 22,242 10-20-2025, 07:01 AM
  Debian vs Mobian henrythemouse 3 3,882 04-06-2025, 02:15 AM
Last Post: henrythemouse
  Battery Management on PinePhonePro: d50zesl0g@mozmail.com 4 5,095 03-02-2025, 11:52 AM
Last Post: d50zesl0g@mozmail.com
  Battery life thread: discussion, support and tips apink 12 15,678 03-01-2025, 10:39 AM
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 9,316 02-25-2025, 08:27 AM
  Reseting the Battery Fuel Gauge franzthiemann 8 9,006 01-24-2025, 08:19 AM
Last Post: teekay
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 2,237 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 5,292 10-28-2024, 10:46 AM
Last Post: Jite
  Disable the GDM service in Mobian. mburns 0 2,113 11-25-2023, 10:19 PM
Last Post: mburns
