Pinephone Pro Earpiece is not working, need help
Some time ago I noticed that I no longer hear my peer during a call. After some investigation and trying different images I installed factory test image from here: https://wiki.pine64.org/wiki/PinePhone_P...e_Checking
No sound can be heard during earpiece test even there . So I come to conclusion that Earpiece is not working on my device at all. It was working previously, sadly I cannot confirm exact point when the issue started.
Is there anything I can do with that?
(03-02-2023, 01:52 PM)silverwing Wrote: Some time ago I noticed that I no longer hear my peer during a call. After some investigation and trying different images I installed factory test image from here: https://wiki.pine64.org/wiki/PinePhone_P...e_Checking
I am not sure does this help but for me some things cause issues with earpiece audio:
These all might be coinsidents so take them as they are (some stranger from the internet is just telling you something Big Grin )
- When my wifi/bluetooth killswitch was off it somehow cause pulseaudio suspending really fast
- Newer kernels cause audio issues for me on Mobian, PMOS and Manjaro
- Before I upgraded Tow-Boot to latest version audio was not that reliably functioning (no idea what my Tow-boot version was but I received my PPP like three weeks ago)
- If I suspend as root it will cause audio issues (for example with sleepwalk scripts or similar)
Hope you will get working audio back Smile
If the factory test image also does not work, you might also have a faulty part.
Measure the resistance between the pins. If there is no connection, it's dead.
I created a thread for this exact issue, that I just fixed today: https://forum.pine64.org/showthread.php?tid=18075
  PinePhone Pro disable Volume Buttons when malfunctioning ArchBene 1 1,505 Yesterday, 10:53 AM
Last Post: FR_IV
  Fix Bricked SPI Flash, Pinephone Pro FR_IV 0 127 06-27-2026, 05:00 PM
Last Post: FR_IV
  performance wise which iphone does the pinephone pro compare to? heocb 2 1,624 01-24-2026, 01:01 PM
Last Post: heocb
Exclamation Pinephone pro stuck while booting Supervisor 3 2,914 10-07-2025, 02:46 PM
Last Post: Supervisor
Question Are there plannes to create a new and more powerfull PinePhone Pro? Nima0908 5 13,183 08-18-2025, 04:12 AM
  Pinephone pro packet injection for internal wifi chipset covar 3 5,174 07-02-2025, 02:03 PM
  RTKLIB PinePhone Pro GPS jlaba 1 1,987 05-02-2025, 12:43 AM
  PinePhone Pro Explorer's edition Qualcomm modem recovery shifras 11 12,328 02-28-2025, 07:03 AM
Last Post: tensa1000
  PinePhone Pro EDL boot by shorting contacts ozkenlc 3 5,474 09-18-2024, 04:59 AM
  PinePhone's LED is blinking, but doesn't start zvavybir 0 1,855 09-06-2024, 02:39 AM
Last Post: zvavybir
